Last triggered at value is intended and you would have to experiment with the luxury sensor. Specifying multiple sensor will activate the lights if any of those sensors activate. Maybe create a template sensor to be on when both sensors are on.
Sure, maybe a future release can contain an AND not only OR for sensor. For the moment will try to create a template sensor as suggested, thanks
Raise a feature request on GitHub please if you have an account
for anyone interested thatās the template
binary_sensor
sensors:
motion_and_low_light_kitchen:
value_template: '{% if is_state("binary_sensor.pir_kitchen", "on") and states("sensor.illumination_kitchen")|float < 40 %} on {% else %} off {% endif %}'
device_class: motion
friendly_name: Motion and low light Kitchen
Dank u Bob. I will try this next week when I will be on site again. Enjoy the weekend, V
I have the component installed, but for the life of me I canāt figure out how to call it, in the automation.yaml or itās own config file? Thanks in advance
It creates an entity_id with lots of attributes related to the motion sensor in regards of trigger and timer
Check dev-state and then entity_id that start with lightingsm.YOUR_ENTITY_NAME_HERE
How to use the attributes? Well you will need to think by yourself or look around for examples
Thanks for the reply, Iām aware of how to use attributes. Just couldnāt figure out why I wasnāt seeing the sensor. Iām still not seeing it, the lightingsm.py file is in the custom components folder. I am using hassio, maybe thats why Iām not seeing it? Iām not getting any errors.
I am using also HASSIO, and just put the file in custom_component.
Did you do a lightingsm sensor in configuration.yaml?
That was the part that was messing me up, I was thinking it would create a generic entity to use in automations. Not realizing that I needed to create one each for multiple sensors.
For each motion activity you want to monitor you add a sensor. Below one sensor
Edit, i canāt format it from my phone but itās the usual yaml formatting
lightingsm:
motion_light_entrance:
sensor: binary_sensor.pir_entrance2
entity: light.table_lamp2
Got it all working, Will be testing out after dark. Thanks for the help guys.
lightingsm:
front_door:
sensor: binary_sensor.front_door_motion
entity: switch.front_door_switch
delay: 30
front:
sensor: binary_sensor.front_motion
delay: 30
garage:
sensor: binary_sensor.garage_motion
entity: group.frontlights
delay: 30
west:
sensor: binary_sensor.west_motion
entity: switch.south_west_switch
delay: 30
ne:
sensor: binary_sensor.ne_motion
entity: switch.back_door_switch
delay: 30
nw:
sensor: binary_sensor.nw_motion
delay: 30
east:
sensor: binary_sensor.east_motion
delay: 30
se:
sensor: binary_sensor.se_motion
delay: 30
I recommend you checkout my component. It will render all those automations unnecessary and solve your problem.
There is no need to do anything with the attributes All automation is taken care off. If you wish to do more advanced things you can of course use the attributes and do more funky stuff. Let me know what you come up with
Thanks for this component, itās working great!
@ Klagio
Might I ask what hardware you got for your 433mhz detector setup? And how did you bring it into home assistant? (which component)
And how will it compare to your other sensors in terms of detection delay, blind time and false positives?
I am still sitting on my fibaro oneās, which seem to get more unreliable every day, so I really need to find a proper solution. In fact, after a complete reset of my HA installation & factory reset of all my 4 fibaro multisensors, I now have 2 of them in ācrazyā mode (once they detect motion, they will get into a on/off loop).
Any 433MHz PIR sensor that works (90% of those in the market work) with the RF Bridge of Itead flashed with Tasmota. I recommend this bridge and not the Broadlink, because its way easier to setup. There are threads on this forum that talks extensively about both (bridge and compatible PIR), if you donāt find them will post the link.
Knowing @danny component before I would have just used those 433 and not Aqara or Zwave. For PIR sensor the simplest is the better
yep, same pain as mine. I experienced the same crazyness with one zwave fibaro clone (neo coolcam) out of three.
I didnāt play too much with the 433MHz, but soi far detection time is instant. What is blind time? If you mean after how long they will be ready again, after a trigger, its almost instant probably few seconds.
False positive I do not think I had any, but I didnāt check it verey well, so far I installed just one in my entrance.
Basically a 5 Euro 433MHz PIR is better then a 10 Euro Aqara PIR, better then 25 Euro zwave coolcam PIR and betther then a 50 Euro zwave Fibaro PIR ā¦
Also battery time needs to be checked, mine is on since 1 month, time will tell
please share your results, thanks
After said all that, I do think that a perfect presence sensor (we need that rather then motion, right?) its a thermal sensor
