Any reason why my motion sensor is behaving in this way.
Its just constantly sending on/off commands. Connect via a ESP32dev board.
Cheers
INFO Reading configuration /config/esphome/test.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing test (board: esp32dev; framework: arduino; platform: platformio/espressif32 @ 5.2.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- AsyncTCP-esphome @ 1.2.2
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
Compiling /data/test/.pioenvs/test/src/main.cpp.o
Linking /data/test/.pioenvs/test/firmware.elf
RAM: [= ] 12.4% (used 40552 bytes from 327680 bytes)
Flash: [===== ] 49.5% (used 907849 bytes from 1835008 bytes)
Building /data/test/.pioenvs/test/firmware.bin
Creating esp32 image...
Successfully created esp32 image.
esp32_create_combined_bin(["/data/test/.pioenvs/test/firmware.bin"], ["/data/test/.pioenvs/test/firmware.elf"])
Wrote 0xef0d0 bytes to file /data/test/.pioenvs/test/firmware-factory.bin, ready to flash to offset 0x0
========================= [SUCCESS] Took 10.82 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of test.local
INFO Uploading /data/test/.pioenvs/test/firmware.bin (913616 bytes)
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from test.local using esphome API
INFO Successfully connected to test.local
[20:13:14][I][app:102]: ESPHome version 2022.12.3 compiled on Dec 31 2022, 20:12:38
[20:13:14][C][logger:293]: Logger:
[20:13:14][C][logger:294]: Level: DEBUG
[20:13:14][C][logger:295]: Log Baud Rate: 115200
[20:13:14][C][logger:296]: Hardware UART: UART0
[20:13:14][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Sensor'
[20:13:14][C][gpio.binary_sensor:015]: Device Class: 'motion'
[20:13:14][C][gpio.binary_sensor:016]: Pin: GPIO13
[20:13:14][C][captive_portal:088]: Captive Portal:
[20:13:14][C][mdns:103]: mDNS:
[20:13:14][C][mdns:104]: Hostname: test
[20:13:14][C][ota:093]: Over-The-Air Updates:
[20:13:14][C][ota:094]: Address: test.local:3232
[20:13:14][C][ota:097]: Using Password.
[20:13:14][C][api:138]: API Server:
[20:13:14][C][api:139]: Address: test.local:6053
[20:13:14][C][api:141]: Using noise encryption: YES
[20:13:14][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:14][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:15][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:15][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:16][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:16][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:17][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:17][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:18][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:18][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:19][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:19][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:20][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:20][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:21][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:21][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:22][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:22][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:23][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:23][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:24][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:24][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:25][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:25][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:26][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:26][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:27][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:27][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:28][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:28][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:29][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:29][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:30][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:30][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:31][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:31][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:32][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:32][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:33][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:33][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:34][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:34][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:35][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:35][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:36][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:36][D][binary_sensor:036]: 'Sensor': Sending state OFF
[20:13:37][D][binary_sensor:036]: 'Sensor': Sending state ON
[20:13:37][D][binary_sensor:036]: 'Sensor': Sending state OFF
