Hello, I have a few PIR sensors scattered around my house. I’m using the device_class: motion
with them and they work great. I don’t update my ESPHome devices regularly but when I do update them (or they get rebooted) the PIR sensors come up as Unknown
instead of Clear
. While this is probably wanted in most cases, I don’t want it to be the case on my setup. What’s the best way to set the default state to Clear
on a motion sensor after powerup on ESPHome?
Heh, I thought I was going to answer my own question… I tried this:
publish_initial_state: true
but it didn’t work. After setting that and reloading the FW it still comes up as Unknown
Are you using API or MQTT for your HA connection?
I’m using the native API
What version ESPHome? I have a REALLY basic sensor platform using a PIR and a DHT22. The PIR always comes up initially as Cleared.
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
- platform: dht
pin: D1
temperature:
name: "Office Temperature"
humidity:
name: "Office Humidity"
update_interval: 30s
model: DHT22
binary_sensor:
- platform: gpio
pin: D6
Just updated to 2022.10.0 is that what you’re running?
I wonder if it’s my choice of using a delayed off filter…
binary_sensor:
- platform: gpio
pin: D2
name: "Motion detected in Garage"
filters:
- delayed_off: 5min
That’s the only thing different between me and you if you’re running the latest ESPHome version.
EDIT
That was it. When I commented out the filters:
section it came up as Clear
. Even if I waited the 5 minutes it still never came up – until I triggered the sensor, then it would be on for five minutes and then cleared. I wonder if this is a bug… seems like it to me.
You could always log an issue on ESPHome Github issues register - they will tell you quick enough if it’s behaving as designed…
I put it in their system: GPIO binary sensor initial state is Unknown when using filters and delayed_off · Issue #3722 · esphome/issues · GitHub
Thanks for the help!
