Hi guys,
I’m having some issues with motion Sensors connected to a tasmoted Sonoff SV.
I bench tested a pir sensor with an led and it works fine, tested with a Wemos D1 mini pro running tasmota and it works fine. But when I connect them to my Sonoff, they don’t trigger. I can short the output pin and get it to show motion in HA, but nothing will get it to work. A few random activations over the day but not as expected. So I gave up and brought a microwave radar motion detector.
Bench tested with led works fine, smashing actually, turning my head set it off. Connected to the Wemos and HA and works as expected.
Wired it to the SV, nothing. SV is setup correctly, I can short the switch all day and it triggers motion in HA.
Is there something I’m missing?
I’m about to throw the SV in the bin and use the Wemos, relay and motion sensor instead.
It’s for a garage door opener.
