Motioneye integration
Hi everybody,
I’m so excited of everything I’ve done today! Home Assistant is a great tool for automation, and has endless possibilities.
I want to document here the integration I made between Home-Assistant and Motioneye.
The goal is the following: turn on and off motion detection with Motioneye from Home Assistant, and get an entity indicating when a motion was detected on camera:
I’ll show the example with 1 camera, but it’s easily adaptable to many cameras.
Here are the steps to achieve this:
Step 1: Create your cameras in Motioneye
Here, the important setting is “Motion Gap”: that’s the time the sensor will keep on “Detected” after the motion has finished.
Step 2: Create boolean inputs for each camera, for when motion are detected
For each camera, I will have a boolean input to indicate if a motion was detected or not. This field should not be modified manually, since it will be managed by Motioneye in a later step.
input_boolean:
  camera1_motion_detected:
    name: Camera1 - Motion detected
    icon: mdi:eye
Step 3: Create webhooks, to manipulate this boolean
I create two automations, manipulated by webhooks. Those two hooks will change the input declared above:
automation:
- alias: "Motioneye - Camera1 - Motion started"
    platform: webhook
    webhook_id: motioneye-camera1-started
    service: input_boolean.turn_on
      entity_id: input_boolean.camera1_motion_detected
- alias: "Motioneye - Camera1 - Motion ended"
    platform: webhook
    webhook_id: motioneye-camera1-ended
    service: input_boolean.turn_off
Step 4: Declare those webhooks in MotionEye
In the configuration of MotionEye, in the section “Motion notification”, I configure the following commands:
# Run a command (when motiton detected)
curl -XPOST http://home-assistant:8123/api/webhook/motioneye-camera1-started
# Run An End Command
curl -XPOST http://home-assistant:8123/api/webhook/motioneye-camera1-ended
CHECKPOINT
Here, I have configured an input boolean that will be manipulated by MotionEye.
Let’s create a binary sensor from this input now.
Step 5: Declare a template sensor
A template sensor is based on other entities state, so you can quickly create this
binary_sensor:
    camera1_motion:
      friendly_name: "Camera - Mouvement"
      device_class: motion
      value_template: "{{ is_state('input_boolean.camera1_motion_detected', 'on') }}"
Now, let’s imagine you have tons of cameras. You can easily “sum them up” by doing:
binary_sensor:
    all_cameras_motion
      friendly_name: "All cameras - Motion"
      value_template: |
            or is_state('input_boolean.camera2_motion_detected', 'on')
            or is_state('input_boolean.camera3_motion_detected', 'on')
You could also create multiple sensors, depending on your needings.
CHECKPOINT
I now have a fancy icon, and can integrate our motion detection in other automations easily.
But, when I’m home, I don’t want the motion detection to be enabled.
Now, let’s see how it’s possible to make this motion detection enabled or disabled, from Home-Assistant to Motioneye.
Step 6: Enable motion API
Adapt configuration in /etc/motioneye/motion.conf:
# We will need this port, so remember it
webcontrol_port 7999
# Set to off if you want to access it from a different machine (BEWARE! This API is not secured!)
webcontrol_localhost off
After changing this configuration, restart MotionEye to apply changes.
Step 7: Create REST commands
Inside Home Assistant, in configuration, create the REST commands:
rest_command:
  camera_motion_start:
    url: 'http://motioneye:7999/1/detection/start'
  camera_motion_pause:
    url: 'http://motioneye:7999/1/detection/pause'
Those commands will be used later in an automation.
Step 8: Create an input to turn motion detection on and off
This input will be used to turn on and off the motion detection. For example, I have a scenario saying: when I leave home, activate the motion detection.
input_boolean:
  camera_motion_detection:
    name: Motion detection
    icon: mdi:eye
Step 9: Automations for value changing
Now, let’s combine the REST commands with the input, using two automations:
automation:
- alias: "Enable motion detection"
      - platform: state
        entity_id: input_boolean.camera_motion_detection
        to: 'on'
      service: rest_command.camera_motion_start
  - alias: "Disable motion detection"
      - platform: state
        to: 'off'
      service: rest_command.camera_motion_pause
CONCLUSION
This is a perfect example of integration/communication between Home Assistant and MotionEye, showing all the possibilities you have with those tools.
If you see any possible improvement, or have any comment to make, don’t hesitate!
Very nice! Just The kind of step-by-step abstract that I need to get started. Thanks!
That is so awesome! Thanks for taking all the time and sharing!
Only problem for me seems to be that I don’t have access to /etc/motioneye/motion.conf. I guess it is because I’m running HassOS directly on my NUC?
Ho, sorry, I’m using some docker images, not HassOS.
It seems you can enter the container in root using Portainer : Protip: How to get shell in actual homeassistant (or addon) container when using Hassio
I can’t really help here, since I don’t have experience on this.
If you are using the motion addon you can just change the web access setting in the addon config. This is the same as changing the webcontrol value in the motion.conf
Beautiful - so that solves the issue then. Thanks a lot for sharing!
No problem. I’m always getting great advice from these pages, its great to be able to help someone for once
Hi Alexandre,
Thank you for the detailed guide. Some questions below:
  1. Step 2: Create boolean inputs for each camera, for when motion are detected
    In which file do you create this?
  2. Step 3: Create webhooks, to manipulate this boolean
    In which file do you create this? when I open my automations.yaml, there is a line stating the id of the record first like: - id: ‘1584914490976’
  3. Step 5: Declare a template sensor
    The same as above
Actually can you please inform me of on which file are you adding every conf?
configuration.yaml
configuration.yaml
Hi I’m getting this error:
Invalid config for [binary_sensor.template]: [camera1_motion] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->camera1_motion. (See ?, line ?).
It seems that this code is not working:
    camera1_motion:
Look at the docs for the template sensor :wink:
binary_sensor:
    sensors:
      camera1_motion:
You were missing the sensors: line
Thanks. I tried that too, here is the error message:
Invalid config for [binary_sensor.template]: expected dictionary for dictionary value @ data['sensors']. Got None
extra keys not allowed @ data['camera1_motion']. Got OrderedDict([('friendly_name', 'Camera - Mouvement'), ('device_class', 'motion'), ('value_template', "{{ is_state('input_boolean.camera1_motion_detected', 'on') }}")]). (See ?, line ?).
Have you tried the template in dev-tools to see if it gives the expected result?
How do I do step 6?
With an editor.
I can’t find the conf file anywhere.
How did you install motioneye?
From the add on store
See this post Motioneye integration
Hi, I got no motioneye folder there … :confused:
