tyrkelko
(Kobi Tyrkel)
February 28, 2021, 9:04pm
45
This is really awesome!
I’ve been able to easily make my motionEye OS with a USB camera running on an RPi3 separate from my HA RPi installation used as a motion sensor.
Worked great!
Might be good to edit step 5 as follows:
binary_sensor:
sensors:
camera1_motion:
friendly_name: "Camera - Mouvement"
device_class: motion
value_template: "{{ is_state('input_boolean.camera1_motion_detected', 'on') }}"
chris-kuhr
(Christoph Kuhr)
March 19, 2021, 3:30pm
46
Thanks for this awesome guide.
I didn’t manage to get the binary sensor working.
I verifed that automations
“Motioneye - Camera1 - Motion started” and
“Motioneye - Camera1 - Motion ended” triggered, but the input_boolean is never updated.
What am I missing? Some new requirements since some HA update?
chris-kuhr
(Christoph Kuhr)
March 19, 2021, 5:25pm
47
I found the answer in one of my other automations. I need to add data: {} after the service in the action part like this:
- alias: "Motioneye - Camera1 - Motion started"
- platform: webhook
webhook_id: motioneye-camera1-started
data: {}
entity_id: input_boolean.camera1_motion_detected
Now everything is working fine.
Aussi
April 28, 2021, 10:23am
48
Thanks for you help on this. That made it work for me.
altho I still have one nasty thing.
When there s motion detected I have 10 sec delay on the webhook command.
therefore making a sanpshot 10sec later …
Did you notice that also?
filippos
(Filippos)
May 7, 2021, 1:50pm
49
hello
I have installed motioneye on my raspbian buster pi3b+ and plugged in an old usb microsoft camera.
It works great, i get the stream inside motioneye.
Once i install the motioneye integration on my hassio pi3b+ with:
host: http ://192.168.x.xxx:8765
and admin/user credentials
the camera is unavailable and doesn’t receive the stream from the raspbian buster motioneye camera.
What is wrong?
Is it because the host is in http and not https? All access is locally.
Hello all,
If you’re motionEye enthusiast this post announcing a new custom component may be relevant to your interests, and may significantly simplify some of the automations in this thread:
Hello all,
You may have noticed there’s now a motionEye integration in the new release , that allows automated motionEye camera discovery and streaming.
This is the first part of a move of motionEye functionality from a new “full-featured” custom component into Core. It will take quite a while for the full functionality to get through the Home Assistant codereview process, but in the meantime I wanted to announce the custom component and get some feedback.
The custom component offers:
Dynami…
Thanks.
nico1
(nico1)
August 3, 2021, 7:50am
51
Can you please share your motioneye addon config? Here is mine:
motion_webcontrol: true
ssl: true
certfile: fullchain.pem
keyfile: privkey.pem
action_buttons: []
log_level: trace
What am I missing?
Yeh that is the same as mine. So when i want to turn recording on and of I then send a a webcontrol value through a rest command.
ai_motion_right_side_capture_on:
url: 'http://yourip:7999/3/config/set?emulate_motion=on'
method: get
ai_motion_right_side_capture_off:
url: 'http://yourip8:7999/3/config/set?emulate_motion=off'
method: get
nico1
(nico1)
August 19, 2021, 6:06pm
53
Where do you exactly are you writing this? is this into the motion configuration section of motioneye?
mr_white
(Martin)
August 20, 2021, 2:54pm
54
Thank you so much for sharing this!!!
this custom component gives us the binary sensor for using it in automation.
raspi4 with Motioneye server – add-on in home assistant – connected the integration to localhost – all entities are working fine
thank you
btw: I love this community here, always helpful and friendly.
elik745i
(El Nur)
August 25, 2021, 4:47pm
55
Is there any easy way to get motion detection from particular camera into automation?
aceindy
(Aceindy)
August 25, 2021, 5:33pm
56
Define easy….
I use a webhook from motioneye notification section, which triggers an automation in HA
elik745i
(El Nur)
August 25, 2021, 5:44pm
57
yes, I have noticed it, but what to put in there webhook url?
aceindy
(Aceindy)
August 26, 2021, 11:12am
58
so you enter something like:
http://your-home-assistant:8123/api/webhook/some_hook_id
type will be ‘post(query)’
and then create a trigger for it:
automation:
- platform: webhook
webhook_id: "some_hook_id"
elik745i
(El Nur)
September 1, 2021, 1:24am
60
I’m trying to use webhook to trigger event from my camera (motioeye) but can’t get it working:
alias: 'Auto Terace Lights '
description: Automaticaly switch light on terace from terace ptz camera motion notification
- platform: webhook
webhook_id: terace
condition:
- condition: time
after: '18:00'
before: '09:00'
- service: switch.turn_on
entity_id: switch.terrace_lights
- delay:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
- service: switch.turn_off
mode: restart
and in motioneye I have done:
where address is: https://myhomeassistant:8123/api/webhook/terace
Time is 05:00 AM
Why is it not working?
elik745i
(El Nur)
September 1, 2021, 1:52am
62
does not work even with one, that is typo
nickrout
(Nick Rout)
September 1, 2021, 2:02am
63
Do you have ssl set up? If not it is plain http://
elik745i
(El Nur)
September 1, 2021, 2:04am
64
ssl set up and works both from local address and from remote through duckdns HTTPS://
nickrout
(Nick Rout)
September 1, 2021, 2:06am
65
OK what happens when you run the webhook from curl?
