MotionEye motion detection
Hello! I’m rather new to HA and this stuff.
I’m trying to setup an event when motion is detected in motioneye. I can setup event like 'Motion detection turned on" but the detection is always on… There is no option for “on motion detected”.
I noticed that there is some kind of webhook I might be able to use, tho, I’m not sure how to use it. What do I write in webhookID ? how do I get the camera name?
edit: Here are some info
motionEye webhook http://**serverip**:8123/api/webhook/motion_detected
home assistant
alias: MotionDetection
description: ""
  - platform: webhook
    webhook_id: motion_detected
condition: []
  - service: notify.notify
      message: testMessage
      title: testTitle
mode: single
edit2
Might be relevant that I have both HA and MotionEye running in separate dockerContainers in Portainer?
/T
Hi Tobias,
How are you currently integrating with HA. Does motioneye support mqtt. I’m using mqtt with blueiris & that works well. In my case i need to instruct the blueiris server to send both a start & stop packet via mqtt. Or maybe within motioneye you can have the ‘motion off’ signal automatically sent after a couple seconds time out.
Nick
Hey!
I installed both the MotionEye stack and HomeAssistant in portainer. They seem to know about each other because I can view the cameras inside HA. I’m not sure if MotionEye know about HA tho, because the webhook does not reach it seems. I tried postman and it worked fine with HA.
