running HASSIO (latest version), added Motioneye integration, setup my camera, I can view in the Motioneye UI. When I try to use the streaming url provided by Motioneye to view the camera feed (RSTP) from HA lovelace or IE, I cannot get access. I am running duckdns SSL so the url provided by Motioneye is https://xxxx.duckdns.org:8081. I am wondering if I need to port forward the ip on google wifi router (very limited port forwarding capability). Anybody can help me out here?
EDIT: this thread is pretty old. pretty sure the thread predates the motioneye integration
you should probably take a look at the integration first
sorry but i move to frigate a few months back. Live view is low res but viewing recordings is faster and object detection is amazing. Frigate is also less cpu since mostly use Google Coral.
For motioneye I:
add motioneye to my nginx proxy.
I dont think I was able to get iframe to display the non https local site
I used basic authentication provided in nginx to password protect it
I removd nginx config but I belive below is basically same. you have to look at nginx docs to learn how to make username/passwords for password file
