Hey all!
My shade is 60 inches long. What is the current recommendation?
Thanks!
Hey all!
Thanks!
I have a problem with this ESPhome cover.
Installed the code from:
My cover is working when i visit the ESPhome webpage, and i can control my stepper motor.
In home assistant the ESPhome is autodiscovered, but all the entities are switched off.
It says: Switched off by configuration item. I can’t enable the entities.
I tried removing the API key in the .common_blind config, since all my other ESPhome devices are working without API key. Without succes.
Someone know how i can fix this or what i did wrong ?
Does it work now?
Does anyone have a code, where you can control 2 blinds with only one esp32?
Or maybe a dual stepper driver?
Where can I find this STL/model? This looks exactly what I want to use.
I’ve sinced been working on a 3 motor version - I haven’t printed and tested it myself yet but you’re welcome to try!
https://www.printables.com/model/397730-triple-28byj-48-motors-motorized-blind-driver
Don’t know if you’re still interested, but I’ve posted my work in progress design for a 3 motor version - Printables
Thanks for the link, I checked it out this morning. But by chance, can you post the 2 motor version too? I am hoping I can use this for my horizontal blinds without putting a motor on each end.
Also, are you using just one stepper driver, or are you using two?
Thanks for the help.
Ok, I’ve posted the dual motor version as well now - Printables
Just one stepper driver, the motors are wired in parallel to it.
i have the same issue. roller shade too heavy. must use a bigger motor like the Nema 17 as seen here. Printables
sadly his instruction is very vague. i cant seem to make his code work.
I am very interested.
What controller do you use for 3 motors in parallel?
Do you think this version would tighten a blind with a length of 170 cm and a height of 150 cm?
Thank you very much.
I use a NodeMCU connected to an a4988 stepper motor driver like this
You adjust the POT on the a4988 to supply enough current to run the motors in parallel.
And in order to do this, the 28BYJ-48 stepper motors are modified from unipolar to bi-polar like this
Hi.
Please add your actual code. Some changes in HA code I think because in logs I have blinking message “Connection closed / Connection succesfully” in loop.
I think the problem is in code. Something with API.
[edit]
All is ok . I confused GND with CMD. 10 hours lost … God damn it Frank.
I need help. I use code from zuberio to open the window in the greenhouse. I need to move 0 point and endstop to “Close”. Just replace words “close” to “open” and “open” to “close”. Opening and closing works fine but some mishmash with reporting position. Can u help me with this?
I built a motorized blind a while ago and it took several versions to prefect it. I wanted to use the same motor as tung256 with a built-in encoder.
- platform: rotary_encoder
pin_a: 14 #D5 yellow
pin_b: 12 #D6
publish_initial_value: True
restore_mode: RESTORE_DEFAULT_ZERO
on_value_range:
- above: 28600
then:
- switch.turn_off: positive
- lambda: !lambda |-
id(zaras_blind).current_operation = COVER_OPERATION_IDLE ;
- cover.template.publish:
state: CLOSED
- below: 0
then:
- switch.turn_off: negative
state: OPEN
- platform: dht
pin: 13 #D7
model: DHT22
temperature:
name: "Zara's Blind Temperature"
accuracy_decimals: 1
humidity:
name: "Zara's Blind Humidity"
update_interval: 50s
- platform: uptime
name: Zara's Blind sensor Uptime
- platform: wifi_signal
name: Zara's Blind sensor Signal
update_interval: 120s
# Exposed switches.
switch:
name: Zara's Reset count
turn_on_action:
then:
- sensor.rotary_encoder.set_value:
value: 0
- switch.turn_off: resetc
# Switch to restart the Zara's Outside Blind.
- platform: restart
name: Zara's Outside Blind Restart
- platform: output
output: 'shade1'
internal: true
- platform: output
output: 'shade2'
internal: true
output:
- platform: gpio
pin: 5 #D1 PURPLE
- platform: gpio
pin: 4 #D2 BLUE
cover:
device_class: blind
name: "Zara's outside blind"
optimistic: TRUE
# has_position: true
# position_action:
# - stepper.set_target:
## id: encoder1
# target: !lambda "return (pos*1000);"
open_action:
if:
condition:
lambda: 'return id(zaras_blind).is_fully_closed();'
then:
- switch.turn_on: negative
id(zaras_blind).current_operation = COVER_OPERATION_OPENING ;
- delay: 38s
close_action:
if:
condition:
lambda: 'return id(zaras_blind).is_fully_open();'
then:
- switch.turn_on: positive
id(zaras_blind).current_operation = COVER_OPERATION_CLOSING ;
- delay: 35s
stop_action:
device_class: blind
name: "Zara's outside blind manual"
assumed_state: true
open_action:
close_action:
stop_action:
this is my first post , so I’m sorry about the formatting.
Could you please provide a wiring diagram?Thank you very much
Is there any fundamental reason why Home Assistant does not support TB6600 stepper motor drivers, aside from the effort involved?
It seems like a common generic driver like that would be useful for motors like the Nema 17. I bought this combination a while ago for another project before finding this thread, but it seems that the only other person here that I noticed was attempting to use this driver was unable to get it operating correctly.
Hello. I’m trying to use this code https://github.com/RoadkillUK/Motor-on-a-Roller-Blind-for-ESPHOME/blob/1941b2f2ae5df4d7d8e34114680f743264764509/myblind.yaml, which was found in the current topic, for the stepper motor based on ULN2003. There is using “template cover platform” inside Template Cover — ESPHome, which has “position_action” with “pos” variable inside. While I was trying to install it, I got the following error:
error: 'pos' was not declared in this scope
As I understood, the “pos” variable is a part of “template cover platform” and should be predefined under the hood. But something was going wrong…
Many thanks for any help or ideas! Much appreciate!
To fix this, you should define the pos
variable before using it. For example, you can add it as a new global variable. Update your globals
section like this:
Make sure to adjust the initial value or other properties of pos
based on your specific use case.
globals:
# ... other global variables
- id: pos
type: float
restore_value: True
initial_value: '0.0'
