Hi haven’t seen any progress at all from @Leviosa on the zone or their beta HA integration. Hopefully Tony can respond.
I emailed their customer support and showed them this thread. The rep I worked with said he would bring it up in a staff meeting and that was yesterday so hopefully there will be a fix soon.
I have more shades I want to order but I’m holding off until I know this is going to work. Thanks all!
Great, thanks for doing that. Hopefully @Leviosa will respond here.
Quick warning: try creating a new user first if you’re thinking of the Leviosa “Zone” hub.
HA needs the “Zone” hub
The Zone needs the app to set it up
The App needs a user account
The user-account creation is failing exposing an error in the backend
Leviosa doesn’t admit that they understand it’s broken.
Most of us would be using the “Zone” to interface with HA, but the Zone needs the App to be setup, and the App needs a new login created. Sadly, any combination of user and password (for example, user=“bob@example,com” pass=“hunter2hunter2”) fails with what looks like a common DynamoDB error (cloud backed by AMZ user user database in DynamoDB?).
Either way, we cannot fix the broken backend, and while it’s broken, we cannot set up the Zone, so we cannot have a hub discovered by HA, so we cannot use with HA.
Please try to setup the App with a new account before you place your order.
Hi @W0lfm4n … The shades are Custom RF, like a lot of older home automation. I don’t know yet whether the RF is fire-and-forget or has returns about state (ie how competitors keep you updated about battery levels in the blinds)
Remote ==(RF)==> Blinds
The “Zone” hub is a Wifi client, RF transmitter:
LAN → your_WiFi_AP —(Wifi)–> Leviosa_Zone ==(RF)==>blinds
This is the same as the Hunter-Douglas, at half the price. I’m unsure yet whether the Zone Hub transmitter will go through drywall as mine isn’t connecting yet, and the hand-held A114 “Emitter” used to set them up doesn’t make 20 feet when there’s a hollow interior (drywall) wall in the way. I’m hoping the Zone transmitter transmits with more power when mine starts working.
Good news Leviosa customers who desire HASS capability! Leviosa has finally released an update to re-configure Leviosa shades for HASS. See here Our next step is to formally complete the PR for HASS so setup is automatic.
Hi Tony
I am working on a new house design with a lot (I mean a LOT) of blinds. Whole house will run on HA platform. Currently, my architect and interior designer are planning Lutron rollers and blinds, which just that will probably require separate mortgage - I already have Lutron in my current residence
I am open to consider Leviosa, but I want to test it first in my current house (everything I am designing in should go thought this test)
Currently I have “new” construction window @ nearly framed ADU (open walls yet, not drywall and electrician is working on all electrical wiring - Line Voltage and Low Voltage) and I would like to add another blinds on existing sliding door - should be battery powered. That will check both powered and battery options. Any carpenter fixes (if needed) can be done by my contractor. Let me know with whom I need to work @ Leviosa. Please send me PM with the contact information
Vladi
Hi Vladi-
Leviosa Shades can meet your needs, and offer considerable cost savings. Lutron is a fine company - and motor shades no longer need to be so expensive. Afterall, tubular motor technology is more than 50 years old. Expect a PM shortly.
If you choose Leviosa, I would check whether you can create a user ID in their website first – that was a required part of the install. It’s a local-polling, but needs cloud during config. And needs a multi-channel remote to set up blinds before automating with a hub,
Keep in mind that Leviosa seems to be a fire-and-forget: it fires off a command, and assumes the command was received and processed by the blinds. Quite often, I have one of 5 blinds not doing as the scene commands, yet the hub reports back to HA that all five are down or up or whatever.
Well. SmartThings integration has finally annoyed me enough (transitioned everything off of ST years ago, but kept ONLY for Leviosa integration). Now, ST ↔ HA is not working at all, so revisiting your HA integration.
Just downloaded the Aug '23 ‘beta’ version, installed, rebooted and tried to setup…
Back to this error. Running Unifi DreamMachine Pro and a separate IoT VLAN - which your hub is on.
Can we please get an update to the HA integration that simply allows hard-coding the hub IP during setup vs. the SSDP that’s clearly and still causing the issue(s)?
Thank you.
Hi @Leviosa,
We really appreciate the embrace of Home Assistant. I’m looking to buy 10 rollers and this is very much swaying me towards Leviosa (and the cost vs. Serena).
Two major wish-list items from me that are holding back Lutron switchers:
(1) The Zone product is not how this community wants to deal with smart home integrations. Please consider embracing Zigbee/Thread/Matter so that we can ditch the proprietary hubs and 433mhz altogether. I’ll have to buy three Zones and deal with these extra devices on my wifi and their vampire draw just to relay a few bytes of data now and again. If you’re committed to 433Mhz, please make a Zone Pro with ethernet instead of wifi and raise the 6 groups limit.
(2) Give us a very thin and elegant remote that can be installed inside a normal 1 gang adapter. This seems to be spirit of the “Group Wall Mount Remote”, but that device needs to be significantly thinner and more elegant design; and be able to be installed in a 2-gang wallplate to control blackout vs. sheer. The two group design is not usable by mortals to try to understand which shades are on channel one vs. channel two with a right and left LED/button. The “UI/UX” of the buttons is how humans are interacting with your product and it doesn’t read like a premium product currently compared to your competitors.
Thanks for giving us a more open and lower cost option; we’re rooting for you and hope this feedback can help you evolve to capture more of the premium and HA market.
A final wish-list item for me is to offer a drape-track motor – I need four of those too and it’s down to Lutron and Somfy with today’s choices and would love a disruptive third option.
HASS Community-
We heard you, and now Leviosa Motor Shades offers a Matter motor over Thread option. This eliminates the Zone (wifi hub) for a direct IP connection. Setup is simple - the HASS App allows device linking of Matter devices - just scan the QR code on the motor.
And our Matter remote controllers connects in a 1 gang box, with push button control (on/off) for each group.
Is there specific instructions on your web page for install with matter? What does the 1 gang box refer to? Is that power for the remote controller?
TIA
Steve
Specific HASS integration instructions here. Thanks to user Bruce F for his experience integrating Leviosa Matter Shades with HASS.
The remote controller uses a simple coin battery (included), and requires NO external power source. You can mount it in a gang box, or simply mount it flush on the wall.
This is incredible news, Tony - I’m specing my next project with Leviosa rollers and will give it a try!
I totally installed too soon!
@Leviosa Certainly nice that there’s now an option to not purchase a hub and go direct via Matter.
Two issues here however. 1) I’m an existing user, who already purchased and is using a working hub. 2) My network at home is only Zigbee & ZWave - not Thread/Matter.
I’m asking again if there’s a way someone on your side and update the existing code to simply hard-code in an IP vs. the SSDP discovery function. Wish I had the skills to do it myself, but all my attempts have failed.
TY.
Well, when in doubt, ask ChatGPT, lol.
Edited the aioleviosa.py file:
async def discover_leviosa_zones() -> dict:
"""Use a fixed IP address for Leviosa Zone."""
fixed_ip = "1.2.3.4"
_LOGGER.debug("Using fixed IP address for Leviosa Zone: %s", fixed_ip)
# Using a more descriptive UDN
ZonesFound = {
"uuid:leviosa-zone-1": fixed_ip
return ZonesFound
Obviously change fixed_ip to match your Zone’s IP address.
As of 2025.1 the leviosa integration stopped working. I know they are more focused on matter/thread motors now but I still have a bunch of shades and 2 zones today. I dug into the error and resolved it. Error was:
Logger: homeassistant
Source: custom_components/leviosa_shades/cover.py:7
integration: Leviosa Motor Shades Zone
First occurred: January 13, 2025 at 11:55:24 PM (1 occurrences)
Last logged: January 13, 2025 at 11:55:24 PM
Error doing job: Task exception was never retrieved (None)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2349, in async_forward_entry_setup
result = await self._async_forward_entry_setup(entry, domain, True)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2380, in _async_forward_entry_setup
await integration.async_get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1108, in async_get_platform
platforms = await self.async_get_platforms((platform_name,))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1185, in async_get_platforms
import_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1173, in async_get_platforms
platforms.update(self._load_platforms(platform_names))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1098, in _load_platforms
platform_name: self._load_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1272, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1304, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1026, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/leviosa_shades/cover.py", line 7, in <module>
from homeassistant.components.cover import (
...<5 lines>...
ImportError: cannot import name 'DEVICE_CLASS_SHADE' from 'homeassistant.components.cover' (/usr/src/homeassistant/homeassistant/components/cover/__init__.py)
A few constants in cover had been deprecated for a while and finally removed in this PR Remove deprecated cover constants by edenhaus · Pull Request #131797 · home-assistant/core · GitHub
To address this we just need to switch the cover.py in the leviosa integration to use these new constants.
First change the import for the cover component:
from homeassistant.components.cover import (CoverDeviceClass, CoverEntity,
CoverEntityFeature)
Then update it’s usage in 2 places:
in device_class function:
@property
def device_class(self):
"""Indicate we're managing a Roller blind motor group."""
return CoverDeviceClass.SHADE
And in supported_features:
@property
def supported_features(self):
"""Bitmap indicating which features this device supports."""
return CoverEntityFeature.OPEN | CoverEntityFeature.CLOSE | CoverEntityFeature.STOP
Then save this file in the home assistant custom components and restart HA.
@Leviosa any chance you can make this change in the zip hosted here for everyone to use Beta Testing for Home Assistant – Leviosa Motor Shades
I have personally started a GitHub repo to manage the Leviosa custom component. In this repo, all the deprecation warnings and errors are fixed as of today.
I do not believe Leviosa has plans to keep the custom component current any more. This is based on my email communications with the support team.
