Motorola Cameras
Can anyone help with 0112-01.19.36 or know where I can find it?
Hey, I got the Motorola Focus 72.
According to the http://10.0.0.###:8080/fwupgrade.html it is:
Model: 0172
with
Current Version: 03.10.34
Can anyone tell me on how to make this usable for home assistant? :open_mouth:
I have Motorola Comfort 45 (model 0335, fw 03.40.00), I try all commands and also fwupdate page but I get always ERR_CONNECTION_REFUSED. Did I miss something?
When I try look into pages:
https://ota.hubble.in/ota1/0335_patch/version.txt
https://ota.hubble.in/ota1/0335_patch/history.txt
I got info that oldest version of FW is 03.30.05 so it would by possible to rollbeck to FW 03.10.11 even I found way how to connect to fwupgrade page on my camera.
Do you have some suggestion how to integrate it into HA,
can you explain a little your proposed solution? I’ve seen the proxy in github, but I don’t know how it works. I have same problem to include in my home assistan for this camera: https://www.amazon.com/-/es/Motorola-Peekaboo-WiFi-1080p-Monitor/dp/B082XXT9L5
thanks in advance!
The basic idea was that I emulated their endpoint. Caught all messages going back and forth. They did no validity checks on the SSL certificate presented so I could just man in the middle it all. However this seems to have changed and I have not been able to get time to check what have changed so it is currently also broken.
Did you solve that? test_infra.html do not turned on the lights…
No, I’ve never been able to fix it…
Do you still have a copy of the FW mentioned in previous posts?
https://ota.hubble.in/ota1/2855_patch/2855-03.10.11.fw.pkg
Could you please share it? Thank you in advance!
Installed a new router and my pesky camera has done an update - I’ve lost the original pkg. Would anyone have the files for the 1854 please? (https://ota.hubble.in/ota1/1854_patch/1854-03.10.21.tar.gz)
Dear Peter, I would like to ask you for sharing me link to 2855-03.10.11.fw.pkg as well. I am new user here and therefore I can not send private messages yet. Thank you very much in advance!
Dear Bogdan, please, have you managed to obtain 2855-03.10.11 somehow? If yes, I will be very thankful, if you can share with me. Thank you in advance!
Nope, not yet. As a new user I couldn’t send private messages.
Bogdan, thank you for your reply, me neither. I have tried to contact Peter Nijssen via Linkedin, but unfortunately, no response:-( If I will manage to obtain it somehow, will let you know here.
@bozek same here, I will let you know when @ptnijssen will reply to the private message regarding the 2855-03.10.11.fw.pkg.
Thank you very much @Bogdan_B!
Thank you so much! :blue_heart:
Maybe a stupid question, but how do you guys connect the Hubble connected cameras to HA? Because I seem to be unable to find an integration for it
Anyone still have old firmwares? I need to get rtsp back to work, but download links not work anymode?
Current Version: 0854-03.10.24 (Blocked RTSP)
For ā€œ2855-03.10.11.fw.pkgā€, I get it from https://web.archive.org/web/20200123000544/https://ota.hubble.in/ota1/2855_patch/2855-03.10.11.fw.pkg. Not tested yet.
