Mount Network drive in Hass.io
There have been several other threads on this, but nothing really helped me. I think it should be possible, but I am not sure and I surely don’t know how.
I’m running Rasbian Stretch on my Pi3 and I want to mount a network drive in its share folder. The network drive is a drive that I have attached to my FritzBox.
Any help would be appreciated.
Did you ever solve this? I’m looking to do the same thing.
Can’t be done. Drives needs to be mounted in /mnt, mounting in /usr/share/hassio/homeassistant will not work. If your server runs nfs, you can mount in /mnt and create a symbolic link, but if your server runs samba even with Minshall+French it will be difficult (symbolic links to files work, symbolic links to folders not)
I dont use the samba addon anymore. This gives ne Note flexibility
You should make the mounted volume visible to docker hass.io container first. Check https://community.home-assistant.io/t/solved-hassio-and-volume-mount-issues/141986
Just in case if somebody need it
