Mount remote smb share on hassio
I believe our solution here is the only one that exists which is not a great thing because it’s pretty hacky. Maybe it’s a good idea to ask @pvizeli and @balloob to see if they know of any other way of persistently mounting a remote share (NFS and SMB) — and possibly consider enhancing HA to make mounting of remote folders just a bit more user friendly rather than a startup hack. Hoping it’s already somewhere on the product road-map :slight_smile:
Excellent to hear that all is working @insajd! This was indeed challenging when I switched over from a direct PIP install onto the Supervised solution. My reason & purpose for this mount is to dump motion triggered videos from my Ring doorbell and Blink cameras.
Once I enabled NFS4 on my QNAP then mine worked with both NFS (old) and the NFS4 mount type that you have working. Interesting that you can’t get the old NFS to work.
BTW, I also wanted to go the fstab route but changed by mind. I want my hack to be more “portable” and not impact any config files on the container — if possible. After every HassIO (supervised) upgrade, I click a button in Node RED (runs on host Ubuntu) which basically runs docker command asking the container to create a folder and then reboots the HA docker container. Otherwise HA does not start correctly if I’m listing it under allowlist_external_dirs but the folder doesn’t exist — and then I simply have the same startup like you’re doing though it’s just the full mount command rather than an fstab mount all like you do @insajd. This is what I run after every Supervisor upgrade via Node RED:
sudo docker exec -i homeassistant mkdir /mnt/_NASVIDEO && sudo docker container restart homeassistant
