i use fstab but after update the fstab is rewriten
Same here. I get this error:
... bad option; for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount.<type> helper program.
I am trying to access a share on my unraid server from within home assistant on another server. Did you get this working?
Iām trying to mount a network folder on HA but I need to set user and password to open it, is it possilble to implement user authentication on this automation?
For everyone desperately trying to mount their network shares to Plex, here is my solution:
This worked for me for a couple of years but has now stopped working. Could it be caused by one of the latest HA updates? Is this solution still working for anyone?
If I copy and paste the mount line from secrets.yaml it immediately mounts the share.
mind if I ask what happened to the HA desktop app for Windows?
Por el Amor de Dios, que esta pasando con los Montajes en Home Assistant?
Tengo una RPi4 con un disco USB directo (donde esta HA) y un segundo con alimentacion que quiero montar y no puedo xq me sale esto:
mount: permission denied (are you root)
Claro, que soy Root!
Pregunto, alguien pudo montar una unidad USB, sin necesidad de crear scripts y solo por comandos?
For who is searching for remote SMB connections and ends up on this thread, here is the easiest solution since the 2023-06 HA release:
Nice, exactly what I was looking for to mount my synology shares for use with the sonarr/radarr/sabnzbd addons.
