Mounting Muino smart water meter reader
I bought a Muino smart water meter reader from Martijn van Wezel, but have difficulties mounting it on my water meter. The reader is a.o. compatible with a Sensus 620 water meter. Because my meter has “Sensus” on the “dial plate” I thought it was a 620 but apparently I was mistaken. I add a picture of my meter. I also add a picture from the Muino website indicating how the reader should be mounted on a Sensus 620. The muino comes with 2 short screws. The Muino does not fit smoothly at the surface of my watermeter. I have following questions:
  • Are the 2 studs (A and B) on my meter indeed the studs it be used.
  • The 2 designated mounting “holes” are blind holes. Should I drill them open.
  • Should the studs A and B fall into the mounting holes of the reader.
  • Should the white rim with cap be removed off my meter? I already tried to remove it but without success, also because of fear to break it when applying too much force.
I’m pretty sure, you have better luck contacting the seller for your questions.
Good advise, but I tried that already (and, so far, he didn’t respond).
I will answer my own questions, maybe it will help someone later.
  • The 2 studs (A and B) on the meter are indeed the studs to be used.
  • The 2 designated blind mounting “holes” don’t have to be drilled open.
  • The studs A and B fall into the mounting holes of the reader.
  • The white rim with cap should be carefully removed from the meter with f.i. a screwdriver. The rim will get slightly damaged, but that doesn’t matter (store it in a save place: the number of the meter is written on it).
  • The two screws are not needed (in this case).
Can you share a picture? I cant get the two studs to fit in the holes (the studs are to thick).
Pictures are shown in my original post.
