My hope was, that mounting an USB-stick is as simple as in plan Debian.
As root-user I get the message “permission denied”, no matter which directory I use for mounting.
ls -lah shows, that I have all root-permissions to read/write an execute. I’m able to use chmod 777 on each single directory.
But mount leaves me which “permission denied” - all the time. Even if I make my own directory, f.e. as subdirectory of /home … the same problem occurs.
thanks for your immediate reply. I’m happy to get in contact with a specialist
I’m a rookie … but I try to explain, what I did:
HASS came to me by just downloading the image, inserting it into my raspi3 and starting. I’ve no idea, what kind of installation that is. I just followed the checklist (sorry …).
My ls - lah looks like this:
total 112K
drwxr-xr-x 1 root root 4.0K Aug 25 11:34 .
drwxr-xr-x 1 root root 4.0K Aug 25 11:34 …
-rwxr-xr-x 1 root root 0 Aug 6 18:07 .dockerenv
drwxr-xr-x 2 root root 4.0K Jul 9 18:15 addons
drwxr-xr-x 2 root root 4.0K Aug 25 10:07 backup
drwxr-xr-x 1 root root 4.0K Apr 28 13:36 bin
drwxr-xr-x 11 root root 4.0K Aug 23 22:30 config
drwxr-xr-x 4 root root 4.0K Aug 6 18:07 data
drwxr-xr-x 16 root root 3.7K Aug 25 11:07 dev
drwxr-xr-x 1 root root 4.0K Aug 6 18:07 etc
drwxr-xr-x 1 root root 4.0K Aug 25 11:36 home
-rwxr-xr-x 1 root root 389 Oct 20 2020 init
drwxr-xr-x 1 root root 4.0K Apr 30 15:26 lib
drwxr-xr-x 2 root root 4.0K Apr 28 13:36 libexec
drwxrwxrwx 3 root root 4.0K Aug 17 15:12 media
drwxr-xr-x 2 root root 4.0K Apr 14 12:28 mnt
drwxr-xr-x 2 root root 4.0K Apr 14 12:28 opt
dr-xr-xr-x 300 root root 0 Aug 6 18:07 proc
drwxr-xr-x 1 root root 4.0K Aug 25 10:59 root
drwxr-xr-x 1 root root 4.0K Aug 6 18:07 run
drwxr-xr-x 2 root root 4.0K Apr 14 12:28 sbin
drwxr-xr-x 2 root root 4.0K Aug 24 10:44 share
drwxr-xr-x 2 root root 4.0K Apr 14 12:28 srv
drwxr-xr-x 2 root root 4.0K Jun 17 15:47 ssl
dr-xr-xr-x 12 root root 0 Aug 6 18:07 sys
drwxrwxrwt 1 root root 4.0K Aug 6 18:17 tmp
drwxr-xr-x 1 root root 4.0K May 26 15:23 usr
drwxr-xr-x 1 root root 4.0K Apr 30 15:15 var
I’ve no idea, if this shows anything to decide, which kind of installation I have.
ls /dev shows my usb-stick as “sda1”. If I take it out of the raspi, “sda1” disappears.
In case, that I’m in a docker container, that does not allow to use the USB-device, what would be a solution for the problem? Is there a chance to get access anyway?
I do not use monitor and keyboard, but I’m got the Terminal & SSH integration in HA.
Access to the raspi is no problem - its working fine.
Just half an hour ago, I found an blog entry “External USB drive for Hass.io snapshots” dated Jul 17.
It says, that there is a mounting process like: /dev/sda1 /usr/share/hassio/share/ThumbDrive.
The folder structure is today a little bit different. It tried to mount on:
/dev/sda1 usr/share/backupHA (backupHA was setup before)
This question seems to have been asked many times, and I have looked thru the related threads several times but cannot find a definitive answer.
I have tried mounting the from the command line, and that failed (as others report) and so I created an automation event that triggers 15 seconds after restart, and that also fails.
So is it possible to mount a local samba share that I can use to store data, as the storeage on the RPI card is quite limited ?
[core-ssh ~]$ mkdir -p /mnt/router/private; mount -t cifs -o 'username=xxxx,password=xxxxxdomain=WORKGROUP,vers=1.0,noserverino' //192.168.1.1/Private /mnt/router/private
mount: mounting //192.168.1.1/Private on /mnt/router/private failed: Permission denied
Any Update on this? I am also trying to simply mount a SMB share to store some Data on it but I can’t manage it. Its just crazy how many hurdles one has to jump to do such a simple thing.
When trying to mount the Share, I just get the same “permission denied” message as above.
