Mouse Trap 2.0
The best working mouse trap is in my cellar. Have to check it from time to time, which led me to think I could combine two products on a plank:
  1. A mouse trap:
    https://www.swissinno.com/en/products/rodents/mouse/mousetrap-supercat
  2. A vibration sensor:
    https://www.aqara.com/us/vibration_sensor.html
Then I could get an alarm to my mobile phone with Signal messenger when a mouse triggers the trap.
What do you think? Will the trap trigger the vibration sensor? Has anyone tried this already?
Hi, I did the same in a different way. I used a 433mhz proximity sensor such as this one. I added it to the door of this type of trap. The advantage is that it catches them alive. When the door closes, the 433mhz sensor gets separated from its base and it emits a signal. As the signal is only sent in case of movement, it is very battery friendly. The signal is caught by a 433Mhz receiver called Rflink connected to the rpi on which home assistant is, and sends a telegram notification. It works perfectly!
Why not use a mouse trap like this
And put an Aqara door sensor on it
Btw, I think your idea would work. When such a mouse trap triggers it goes airborne lol
Here is my diy setup. I’m using a 433mhz door sensor but it can also be a zigbee one as well.
Just a coat hanger, water bottle and some scrap wood.
When the mouse tries to get back out of the bottle it tips down and the opening is blocked by the wood.
My automation sends me a notification when the bottle tips over.
Here is my ZigBee-fied mouse trap, using an Aquara door sensor. Along with my first catch :smiley:
