Move Aeon Zstick to a new install?
I just reinstalled HA using the AIO installer. Is it possible to import??? the zwave devices currently registered to the Aeon Gen 5 zstick. The devices appear to be still viable when I view them in Open Zwave CP.
When you configure it with hass it should automatically add the devices on the stick, as long as you give the right path in the settings.
I went one AIO raspberry Pi install to another. The settings for each device were the same. I copied my old configuation.yaml to the new installation. The devices just don’t show up. Anything I can check?
Do you have the right device for your stick? It may have changed.
That was it. Thanks
You can also make persistent device names:
https://www.domotiga.nl/boards/1/topics/1222
I had set up using udev rules in my previous install but forgot to add the rules to the new install. Since I moved my configuration file to the new install, the zwave settings were pointed to a now non existant device. Once I redid the udev rules, all went well.
