Move datadisk Help
Hi Guys -
I’m trying to use the ‘Move Datadisk’ in Home Assistant to mount a Seagate 5 TB HDD (Formatted as NTFS, exFAT, FAT32, EXT4). The hard drive is powered via an USB hub. Home assistant is able to recognize the device and it showed /dev/sda.
Tried it last night via the UI and waited for 8+ hours. HA didn’t come back on. So i rebooted my Home Assistant Blue manually this morning. HA came back online but, the HDD wasn’t mounted.
Tried the same via Command line now and it’s over an hour since HA became unreachable.
Any ideas on how to debug this issue further? Thanks in Advance.
FYI, I’m on 2022.8 Core version.
Did you ever solve your issue?
I saw there is a ticket on GitHub describing a similar problem.
Yes. I was able to resolve this issue by using the Home Assistant UI to Move datadisk. That did the trick for me. Good luck!
