Is it possible to move the yaml files (except configuration.yaml) from the /config folder to /config/configuration_files and change the location reference in configuration.yaml?
I’m wondering because this are default configuration files, and I’m worried that Home Assistant wil make new ones after a reboot or upgrade.
You can move the default configurations, and Home Assistant will still read them. However, if you edit them through the GUI, a new .yaml file will be created in the original location.
