Hoping to pick someone’s brain for different solutions for a simple workflow before I commit to building one.
• I have a bunch of motion sensors and have auto-lights working in main living areas of house.
• I’d like the ability to move lights in & out of the “auto/motion automation” on-demand.
The obvious solution is to create input_boolean switches (one for each light), have a separate entity card tucked away in a LoveLace tab so I can manually move each light in & out of the automation. The downside to this solution (in my opinion) is:
• I need to create a large QTY of switches and implement them all into my Node Red workflow.
• From a user perspective the switches are tucked away on another tab so could be frustrating to control?
Ultimately I think it’d make more sense if I could place the switch on the light-card itself (LIKE THIS) so I could just long press the picture-entity card for each light on my home screen to access the switch, but I’m told this isn’t possible.
Any suggestions? How are you guys moving lights in & out of motion sensing on-demand?
I use physical buttons to set the light mode: ON, OFF or AUTO. There are times when you don’t want to have to muck around with a GUI for a simple, quick task. This is one of those times
Thanks, that’s a great idea! I have Xiaomi buttons so I can dedicate one of the three functions to this and use Google Home (or the light) to indicate auto-status when triggered. Thanks!
The Short Version: Sometimes we have guests or other scenarios where I’d like all the lights in the house to be automatic, except a select room.
The Long Version: In the kitchen we’re moving constantly and we don’t spend much time sitting in the living room. Downstairs, we have a chromecast & cinema, and our a table where we play board games with friends.
• Sometimes, we sit still in the Downstairs room - and the lights turn off. So I end up turning the auto-lights off (front page of my hass dashboard), then remember to turn them back on before my wife or I leave the room to rest of house.
• Sometimes we have guests and I’d like all the lights to be automated except in a specific room.
• I’d like my backyard lights to be automated but I won’t have motion sensors throughout the yard, so when we leave via the back door I can trigger the lights & LED strips on for X minutes. But other times we have guests and I want the lights to stay on.
Then I would recommend you have a look at the entity controller (mentioned previous post). Easy to set up, you can use time constrains and override buttons/input_booleans, multiple trigger sensors and multiple lights to activate. And if you have turned on a light on manually the component ignores the light and doesn’t turn it off.
You do have to set up each room or area separately.
I’m keen to check this out in more detail. I saw it a couple of weeks ago but the documentation didn’t seem straight forward. I guess though that you still need more code to set the input_boolean.motion_off from a physical switch / button? or do you not have a non-gui way to turn off the motion control? That was the point of mine, I didn’t want to have to find a phone or tablet just to force the light to stay on
I agree the documentation looks very difficult, but you can just ignore everything about the “state machine” as it discribes the inner workings. You don’t need to understand that for the component to work.
yes, this is just a switch I can use to turn off all motion related events in my house.
input_boolean:
motion_off:
name: Disable motion sensors
initial: off
You don’t need to with this component! If you turn on a light yourself (by pressing a button, using a automation or in any other way), entity controller will NOT turn it off.
I understand that, but there still must be code somewhere to integrate said physical switch into HA. For this, I would still need code to tell HA I had pressed the Xiaomi button. What physical light switches are you using?
What do you mean? Yes it’s just a gui switch, but if you look at the config I posted it’s listed as an override. So no more logic is needed. You can use a physical switch as override too, or a sensor.
True. For HA to use a physical switch you’ll have to integrate it ofcourse. I use a mixture of z-wave (fibaro), zigbee(hue and xiaomi) and wifi (shelly)
Just that this ‘switch’ is only available if you use your phone / computer / tablet etc.
Don’t get me wrong, I like the setup and definitely plan to look into it further. I have a heap of wifi bulbs, so they have no physical switch (other than completely turning the power off to them) hence I use the Xiaomi buttons, but I also have some z-wave dimmers. I need to see if I can utilise those a bit better once I move house. (i have been limited due to being in a rental, so can’t hard-wire)
