Move single integration device database to new install RFXtrx
Anyone finding this I’ve found some more details by digging. Some hints below:
  • Open the homeassistant\data\.storage folder in Visual Studio Code or similar
  • Search in files (Ctrl+Shift+F) for your entity name. Quickly finds all mentions of that entity
  • core.device_registry contains the main device. For RFXtrx devices, the name key will be the device id (friendly id format) and name_by_user will be your device name
  • Search in files for the original id (example AC 123d506:10) where AC is the protocol
  • The search result in core.config_entries will contain the full id.
    • the full id will be the key to the map, ex 0b11003b0123d5060a010f60. This is the one you want!
    • device_id will be something like [“11”, “0”, “123d506:10”]. My guess is that 11 is the protocol (11)
I choose to add the entities one by on in the RFXtrx integration configure => “Choose event code to add” => Paste the full id from above. Then rename and your old automation etc should work.
