need to move form HA yellow (where I used zigbee2mqtt built in) to standalone zigbee2mqtt
I ordered a new USB Stick (will take time to arrive)
till then,
how can I connect the zigbee2mqtt standalon with zigbee2mqtt adone? or in another words can I let zigbee2mqtt standalone use the HA yellow Zigbee board?
I am not known to yellow but zigbee stand-alone means you will install docker with a container on yellow, i.e. next to the HA instance? If you have it run on anohter machine (with dongle) then the only thing z2m needs to know is how to connect to the MQTT on your HAOS/yellow
I’m getting confused.
If running on proxmox, all you need to do is passthrough the dongle to the other Zigbee2MQTT.
Zigbee2MQTT can’t communicate with another Zigbee2MQTT. Zigbee2MQTT only communicates with a MQTT-broker. Both can talk to the same MQTT-broker, provided you have 2 dongles.
