I moved and when I attempt to turn on/off zigbee devices they don’t work. I don’t see any reason why it shouldn’t work? I get errors in zigbee2mqtt, but I don’t understand what I should troubleshoot at this point? Other than moving the server to a new house, nothing has changed.
When I go into zigbee2mqtt I see all devices as availability as “disabled”. Below is a sample log when I attemp to power on/off an existing device. Any suggestions on how to fix this?
error 2024-11-10 09:33:34z2m: Publish 'set' 'state' to 'Family Room Lamp 2B' failed: 'Error: ZCL command 0xb0ce1814030a9f34/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 19767 - 1 - 19 - 6 - 11 after 10000ms)'
error 2024-11-10 09:33:37z2m: Publish 'set' 'state' to 'Family Room Lamp 2A' failed: 'Error: ZCL command 0xb0ce1814030dd70d/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 32536 - 1 - 16 - 6 - 11 after 10000ms)'
error 2024-11-10 09:33:45z2m: Publish 'set' 'state' to 'Family Room Lamp 1A' failed: 'Error: ZCL command 0xb0ce1814030dce98/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 3725 - 1 - 21 - 6 - 11 after 10000ms)'
