Moved from PI to OS X instance, all hell broke loose
(can confirm that running HA on OS X is obviously way faster and effective for response time for automation etc)
Question: how do i get 1) full Zwave network running again, 2) my proper node metadata identified.
Followed instructions and moved Aeotec Stick to new system
Copied final zwcfg_XXX.xml + files to Mac
Started new HA
Redid this 3 times using thread validated multiple but similar instructions, same results
Normal
- Zwave restarts just fine
Symptoms after transition
Zwave network under config shows undefined nodes (and all but two states are unavailable)
with Node :undefined undefined for all real nodes (which is existed before)
Nonetheless, 2 nodes show up under their friendly name and report new values (temp in this case)
Even for those nodes which seem to be reporting the Zwave still shows Node: unavailable unavailable
here is one:
No OZW_Log.txt log being written. Had to add logger logging to see any Zwave activity (example below)
i can copy the old one (from Pi) or delete it completely and no activity ever. -
Leaving the Network to heal fix itself for 1 day does nothing,. No node identified.
If i take the Stick back to the old Pi and fire it up i get the full list back to normal
Nonetheless here is some of the log dump which seems to be showing SOME success in network activity
Please note Node 8 and 12 are repeater and not the sensors reporting temp above, they still show as undefined undefined
2020-01-27 10:07:04.881 Info, Node008, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=8): 0x01, 0x07, 0x00, 0x80, 0x08, 0x00, 0x00, 0x03, 0x73
2020-01-27 10:07:04.887 Detail, Node008, Received: 0x01, 0x20, 0x01, 0x80, 0x61, 0x08, 0xea, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xdd
2020-01-27 10:07:04.887 Info, Node008, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-27 10:07:04.887 Info, Node008, Neighbors of this node are:
2020-01-27 10:07:04.887 Info, Node008, Node 1
2020-01-27 10:07:04.887 Info, Node008, Node 6
2020-01-27 10:07:04.887 Info, Node008, Node 7
2020-01-27 10:07:04.887 Info, Node008, Node 12
2020-01-27 10:07:04.887 Info, Node008, Node 18
2020-01-27 10:07:04.887 Info, Node008, Node 20
2020-01-27 10:07:04.887 Info, Node008, Node 22
2020-01-27 10:07:04.887 Info, Node008, Node 23
2020-01-27 10:07:04.887 Info, Node008, Node 24
2020-01-27 10:07:04.887 Detail, Node008, Expected reply was received
2020-01-27 10:07:04.887 Detail, Node008, Message transaction complete
2020-01-27 10:07:04.887 Detail, Node008, Removing current message
2020-01-27 10:07:04.887 Detail, Node012, Query Stage Complete (Associations)
2020-01-27 10:07:04.887 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Neighbors live=1
2020-01-27 10:07:04.887 Detail, Node012, QueryStage_Neighbors
2020-01-27 10:07:04.887 Detail, Requesting routing info (neighbor list) for Node 12
2020-01-27 10:07:04.887 Detail, Node012, Queuing (Command) Get Routing Info (Node=12): 0x01, 0x07, 0x00, 0x80, 0x0c, 0x00, 0x00, 0x03, 0x77
2020-01-27 10:07:04.887 Detail, Node012, Queuing (Query) Query Stage Complete (Neighbors)
2020-01-27 10:07:04.887 Info, Node012, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=12): 0x01, 0x07, 0x00, 0x80, 0x0c, 0x00, 0x00, 0x03, 0x77
2020-01-27 10:07:04.893 Detail, Node012, Received: 0x01, 0x20, 0x01, 0x80, 0xe0, 0x00, 0x22, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x9c
2020-01-27 10:07:04.893 Info, Node012, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-27 10:07:04.893 Info, Node012, Neighbors of this node are:
2020-01-27 10:07:04.893 Info, Node012, Node 6
2020-01-27 10:07:04.893 Info, Node012, Node 7
2020-01-27 10:07:04.893 Info, Node012, Node 8
2020-01-27 10:07:04.893 Info, Node012, Node 18
2020-01-27 10:07:04.893 Info, Node012, Node 22
2020-01-27 10:07:04.893 Detail, Expected reply was received
2020-01-27 10:07:04.893 Detail, Message transaction complete
notes on Q
- some have mentioned data stored in .storage which needs to move also
- would like to get the OZW_Log.txt logger to work instead of spamming the main log
- copying the zwcfg_XXX.xml seem to have NO impact
- what about the pyozw.sqlite file, i’ve copied it also in some testing with no impact
- i’m ignoring (and not copying in my main research thread) zwscene.xml which seems mostly empty
- USB path for OS X is verified and works, some nodes reporting and properly identified and changed in config files
- I did check permissions on OZW_Log.txt and set chmod 777 OZW_Log.txt
kinda ran out of Community threads to try out and ideas
