Movement sensors
Dear all,
I need some movement sensors to control my lights, I do integrate everything from UI, i do not write code, so i prefer easy setup. Please suggest best option for me. So far i have found this - https://www.amazon.co.uk/Xiaomi-Wireless-Remote-Control-Switch-white/dp/B07KXN6S74
But i do not see any support/.
Select your network system, then your devices. Most motion sensors are battery powered and therefor use a „lightweight“ radio network, like Zigbee, Z-Wave or custom.
I use Philips Hue and IKEA Trådfri sensors indoor. These are Zigbee devices, I have a Zigbee „stick“ as coordinator device.
Thanks for opinion.
I have read about this zigbee stuff, but seems that there is nothing available locally and ordering stuff now takes ages.
Only hub and sensors i have available locally is the one i mentioned in post, but like i said not sure i will be able to work with that,
There is an integration available that might support the Xiaomi Gateway, but I cannot confirm that. AFAIK the Xiaomi devices are Zigbee devices.
  • Intelligent Control Center
    this thing is not aqura, maybe i am wrong.
I am working with the Xiaomi integration and it works fine.
You don’t need to write any code, all your sensors will be recognized by HA.
BUT in your link, it seems that’s the EU version of gateway : dgnwg05lm
DGNWG05LM seems to be a nightmare to make it work in HA, so avoid it
