new here and just starting. I have searched long and hard before picking which server software I would go with. I ended up picking HA because I have a few Tuya devices and you guys support them out of the box.
I have set up my server on a VM and it looks like it’s up and running fine. I can see most of my devices and turn them on and off … fancy stuff with switches to follow.
I am however having a problem and must be missing something … I searched all over and could not find an answer. …
How do I move a bulb from one room/area to another … and delete a device…?
Entities that are configured manually (as opposed to those that are discovered) do not yet have this functionality. I believe it’s on the ‘to do’ list.
Ah so it sounds like I can save my time trying to configure it. I’ll have a read and see if there is a way to get it “discovered” I added it manually in the configuration.yaml. I guess I leave it as is and see about colours on the Tuya bulbs.
I also noticed some eWeLink WiFi relays on e-bay and they seem to be dirt cheap … that’s like hundreds of things I can think of for them
