Moving from Blynk to ESPHOME
I am new to Home Assistant and ESPHOME.
I have an ESP32 where I was running a firmware with Blynk and now I want to switch to ESPHOME, but I have a problem (my knowledge) to do the automation.
I have a cover where I want it to open or close according to the temperature, whether it’s day or night, or if it’s raining.
I’m using the following configuration:
esphome:
  platform: ESP32
  board: esp32dev
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: ""
wifi:
  ssid: ""
  password: ""
  power_save_mode: none
  ap:
    ssid: ""
    password: ""
captive_portal:
web_server:
  port: 80
sun:
  latitude: -0000000°
  longitude: -00000000°
  #name: "Sun Roof"
time:
  - platform: sntp
    timezone: "America/Sao_Paulo"
  - platform: dht
    pin: 25
    temperature:
    humidity:
    update_interval: 60s
  - platform: adc
    pin: 34
    name: "Sensor de Chuva"
    icon: "mdi:water-percent"
    update_interval: never
    attenuation: 11db
text_sensor:
  - platform: sun
    name: Sun Next Sunrise
    type: sunrise
  - platform: sun
    name: Sun Next Sunset
    type: sunset
output:
  - platform: gpio
    pin: 26
interval:
  - interval: 60s
    then:
      - output.turn_on: power_chuva
      - delay: 300ms
      - component.update: sensor_chuva
      - delay: 100ms
      - output.turn_off: power_chuva
binary_sensor:
  - platform: gpio
    pin: 36
    on_press:
      - delay: 150ms
      #- switch.turn_off: rele_fechar
      - switch.turn_off: rele_abrir
      - switch.turn_off: rele_fonte
  - platform: gpio
    pin: 39
    on_press:
      - delay: 150ms
      #- switch.turn_off: rele_abrir
  - platform: gpio
    pin: 32
    on_press:
      # Enable manual mode
      - switch.turn_on: modo_manual
      - cover.open: roof_controller
    on_release:
      - cover.stop: roof_controller
  - platform: gpio
    pin: 33
    on_press:
      - cover.close: roof_controller
    on_release:
  - platform: gpio
    pin: 35
    on_press:
    on_release:
      - switch.turn_off: modo_manual
switch:
  - platform: gpio
    pin: 13
  - platform: gpio
    pin: 14
  - platform: gpio
    pin: 27
    inverted: true
    optimistic: true
cover:
  - platform: endstop
    open_action:
      #- switch.turn_on: modo_manual
      # Cancel any previous action
      # Turn the OPEN switch on briefly
      - switch.turn_on: rele_fonte
      - delay: 150ms
      - switch.turn_on: rele_abrir
    open_duration: 60s
    open_endstop: sensor_aberto
    close_action:
      - delay: 150ms
      - switch.turn_on: rele_fechar
    close_duration: 72s
    close_endstop: sensor_fechado
    stop_action:
    max_duration: 75s
    #optimistic: true
    #assumed_state: true
    #has_position: true
And I want to add the following logic for automation, but since I have multiple triggers I have no idea how to do it.
if (id(modo_manual).state) {
} else {
if (id(sensor_chuva).state == 3.90 for more then 5 minutes) {
} else if ((id(sun_sun_esphome).state == sun.is_above_horizon ) and (id(varanda_temp).state > 20 )){
} else if ((id(sun_sun_esphome).state == sun.is_below_horizon ) and (id(varanda_temp).state > 24 )){
  } else {
Can anyone help me?
