Been running a Home Assistant on a P! 3B+ and a SSD. Pretty much flawless once you leave it alone.
The PI is now limiting me on my configuration and I now have a NUC to play with.
NUC has 8GB/SSD
Whats the best way to deploy with the least amount of work going forward?
HyperV/Home Assistant Image or install the Home Assistant Operating System?
Issues with the PI to get me here are
1.Unifi Controller on the PI with MQTT can not longer run Wifi Controller up (do I need to have the Wifi as a separate virtual?_
2.ESP home not longer got the processing power to compile just takes too long
3.Sight-hound face detection only sufficient CPU/Ram for a single MPEG stream/detection
Final is how to migrate what I have now (backup plus yaml’s) to where I want to get.
What I dont want is to have to update OS etc all the time and kill my Home Assistant instance.
Any advice please?
