Moving from ZHA to Z2M - How to uninstall ZHA correctly?
Hi, I want to switch to Z2M again for various reasons, but I cant seem to find the right way of uninstalling the ZHA integration. Uninstall in the Devices and Services seems to visually remove it, but if I want to restart HA afterwards or just run a configuration check, that goes on forever. I tried rebooting the VM via Proxmox yesterday, which broke the system with HA is still starting.... and not starting a lot of addons automatically.
So after that I chose to get back to my backup from before. Now what is the correct way to get rid of ZHA and install Z2M? I would love to not have to add all the devices again, but I have little hopes on that. See that as additional wish.
I also checked the logs after pressing Check configuration but nothing showed up there what could be an obvious hint. There was one message regarding a template entity thats based off an Zigbee device, I commented that out and the message was gone. Check still running forever. Reboot not possible.
I want to do the same step, ZHA is “in my eyes” total rubbish in the moment, every 2-3 days it doesn’t work properly. In the end it destroyed my raspberrymatic installation. I don’t need any debugging or help here. And I have made every day a full system backup and try to repait it with this, it doesn’t work at all and I try all of my backups. I am totaly frustrated with HA, ok neverless :
I just want to know how to get clean back to Z2M with my devices and try start over with HA and give it another change.
Well I removed the ZHA integration, setup Z2M as usual and re-paired everything. Didnt look back anytime since
Hi Daniel,
How did you manage to uninstall ZHA in the end?
I had a working version of Z2M and decided I wanted to try ZHA and unfortunately did not reflect on that urge for to long, so I installed ZHA while keeping Z2M. Now Z2M will not start and I am begining to wonder if that has anything to do with the fact that I installed ZHA? Perhaps they are they are mutually exclusive?
EDIT: I realised that I can inactivate the ZHA integration which I did and Z2M started again. But I still want to uninstall the ZH.
Cheers
Hit delete
Hi Francis,
Thank you for your swift reply!
Earlier I wanted to remove a device from HA and reinstall it, and that got me into all sorts of trouble as I realized this was virtually not possible. Not for a Noob user like me anyway. So in my experience nothing is as easy as hitting delete in HA :smile: Will that really work? Won’t lots os settings and things be left behind?
No, everything related to ZHA will be deleted.
That is more difficult then deleting an integration.
