Hi everyone, really scratching my head on this one…
So I’m moving from unraid to a ubuntu host with portainer. I’ve been running an installation of HA Core for a few years now in unraid using the ghcr.io/home-assistant/home-assistant:stable image with only 1 mount: a folder (/mnt/user/appdata/Home-Assistant-Core) into /config. This installation works fine as I write this, it can boot up and runs all my devices/automations/etc… (aka the existing install works).
I now want to move this installation over to my portainer install. The portainer install uses a docker volume instead of a bind mount.
So on the new host:
- I start the homeassistant container (same image as I’m using on the old one)
- I stop it
- rm -rf the volume directory that got created (/var/lib/docker/volumes/homeassistant/_data)
On the old host:
- I shut down HA core container
-rsync -avH /mnt/user/appdata/Home-Assistant-Core username@newhost:/var/lib/docker/volumes/homeassistant/_data
→ I double check that this copies over everything including dot files and directories like .storage
Then I start the homeassistant container again on the new host. It gives me the onboarding screen just as with a fresh install.
What am I doing wrong here?
Log on the new host:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2023-08-31 22:48:51.877 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-08-31 22:48:51.878 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration tesla_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-08-31 22:48:51.878 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration auth_header which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-08-31 22:48:51.879 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration afvalbeheer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-08-31 22:48:51.879 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration govee_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-08-31 22:48:51.879 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration auto_backup which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-08-31 22:48:51.880 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration circadian_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-08-31 22:48:52.686 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-08-31 22:48:54.612 ERROR (MainThread) [homeassistant.setup] Error during setup of component automation
File "/usr/src/homeassistant/homeassistant/setup.py", line 288, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 259, in async_setup
await _async_process_config(hass, config, component)
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 976, in _async_process_config
entities = await _create_automation_entities(hass, updated_automation_configs)
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 860, in _create_automation_entities
cond_func = await _async_process_if(hass, name, config_block)
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 989, in _async_process_if
checks.append(await condition.async_from_config(hass, if_config))
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 246, in async_from_config
return cast(ConditionCheckerType, await factory(hass, config))
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 285, in async_or_from_config
checks = [await async_from_config(hass, entry) for entry in config["conditions"]]
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 285, in <listcomp>
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 316, in async_not_from_config
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 316, in <listcomp>
File "/usr/src/homeassistant/homeassistant/components/device_automation/condition.py", line 55, in async_condition_from_config
return trace_condition_function(platform.async_condition_from_config(hass, config))
File "/usr/src/homeassistant/homeassistant/components/remote/device_condition.py", line 26, in async_condition_from_config
return toggle_entity.async_condition_from_config(hass, config)
File "/usr/src/homeassistant/homeassistant/components/device_automation/toggle_entity.py", line 146, in async_condition_from_config
state_config = condition.state_validate_config(hass, state_config)
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 1022, in state_validate_config
config[CONF_ENTITY_ID] = er.async_validate_entity_ids(
File "/usr/src/homeassistant/homeassistant/helpers/entity_registry.py", line 1395, in async_validate_entity_ids
return [async_validate_entity_id(registry, item) for item in entity_ids_or_uuids]
File "/usr/src/homeassistant/homeassistant/helpers/entity_registry.py", line 1395, in <listcomp>
File "/usr/src/homeassistant/homeassistant/helpers/entity_registry.py", line 1364, in async_validate_entity_id
raise vol.Invalid(f"Unknown entity registry entry {entity_id_or_uuid}")
voluptuous.error.Invalid: Unknown entity registry entry 92542f1ce713c028b90e6ebcbb9ce889
2023-08-31 22:48:54.623 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: automation
2023-08-31 22:48:54.625 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: automation')
2023-08-31 22:48:55.596 ERROR (MainThread) [homeassistant.components.homekit] HomeKit Guest Bedroom TV cannot startup: entity not available: {'include_entities': ['media_player.guest_bedroom_tv_2'], 'include_entity_globs': [], 'include_domains': [], 'exclude_domains': [], 'exclude_entity_globs': [], 'exclude_entities': []}
2023-08-31 22:48:55.598 ERROR (MainThread) [homeassistant.components.homekit] HomeKit Bedroom TV cannot startup: entity not available: {'include_entities': ['media_player.bedroom_tv_2'], 'include_entity_globs': [], 'include_domains': [], 'exclude_domains': [], 'exclude_entity_globs': [], 'exclude_entities': []}
