I have hassbian installed on a pi3B and I managed to get zwave working, add 4 zwave devices, configure a few automations, link to my alexa etc. I was just playing around while I waited for my newer pi3B+ to arrive.
Now I have the new pi and a raspbee hat that I want to switch over to. I have that up and running also with a fresh hassbian install.
Can I now just shut down both swap the SD card from the older pi and move the zwave stick over to the pi and continue from where I left off?
Or should I exclude the 4 devices, and just build up the new system?
I am tempted to try the move just as a learning experience but I figured I would see if anyone knows if this approach should work.
I think the included devices are basically stored on the zwave stick and configured in entity_registry.yaml and the other configuration files right. So other than perhaps needing to change a fixed IP I was thinking this should work.
And move the zwave stick over. I have a new stick but think it is best if I move the old one over to the new pi, the other pair will become my work HA config when I am done. Any I correct that the zwave stick holds the pairing info?
Thanks, What do you use to backup? I found instructions on backing up from command line in mac os but it only backs up the boot sector so it doesn’t work.
I installed Apple-Pi Baker also but have not tried that yet.
I am curious how they make the images that install with etcher. Etcher seems to only be a one way tool from img to card.
Thanks, I am looking for a program that works on mac osx. I have used win32 imager but I don’t use a windows much anymore so was looking for a good option for my macbook.
This is the command I mentioned that doesn’t work. I find these steps documented all over the place but when I try to backup a 32gb card with at least 2gb of data it creates a really small image. It seems to only see the boot sector and backs up only that sector. Which of course doesn’t contain any of the data we are trying to backup.
Thanks, I have heard good things. I will give it a try.
I have followed many documents on how to clone raspberry micro-sd cards and these instructions seem to provide the same commands. But when I run the dd command to backup my cards I get an image that is way too small and when I try to restore from them it doesn’t work. So somehow this doesn’t work correctly on mac os or there is something I am still missing. It’s been a while since I tried this but the commands look the same as what I have always tried. I guess the key to using the wrapper tools is they get the commands right
Backup - make sure you get the source right, you dont want anything with a number on the end, e.g. sdb1…4, as you’ll just be backing up a partition, should just be sdb, thats the whole device. Name may vary depending on whether its a HDD or your using an SD card.
Restore - again make sure you get the restore location right, or you could wipe something out. Again should not be something with a number (e.g. sdb1) but the device (e.g. sdb).
Easiest to grab something like GParted to look at your HDDs and get the correct device. Check the size and expected partitions from there. As mentioned be very careful, its secondary name ‘Destroyer of Disks’ isn’t for nothing.
Thanks! that must be the key. Every example I read uses a device with a number on it so when I try it I just get the partition. Thanks for sharing the actual command example, that really helps! I will give this a try. I am an old school command line kinda guy so I was bummed that I couldn’t get this working from what I was reading.
Also there was mention about the sizes of backups can’t possibly be correct.
If run without gunzip, it will backup every block on the device, including empty space, so a 32GB SD card, that only has 100MB of data, will be 32GB.
Gunzip compresses out the empty space, and would compress it down to a bit over 100MB. You will still need to read in, and write out all 32GB though (even with only 100MB used on the filesystem), so it will take a while.
