Moving HomeAssistant to new hardware: Sanity test
I want to make sure I understand how this process is going to work before I do anything. I plan on moving from MachineA running HomeAssistant in a docker container, with other various containers supporting HomeAssistant to MachineB, also using docker containers.
On MachineA I am running a MariaDB container to which HA is pointing. MachineB I plan on using the default SQLLite as the database.
Should I be able to use the HA backup procedure to take a backup on A, then restore that backup to B? Would this have the effect of taking whatever data was stored in the MariaDB container and copying it to Machine B’s HA container’s SQLLite data directory?
For my Z-Wave radio, I planned on taking a backup of the zwave-js-ui container on A, restoring on B, then moving the radio from A to B. The radio will still have links to the zwave devices and the zwave devices themselves will still have links to the radio. The zwave-js-ui container will now have the correct “map” as specified in the radio-devices mappings on the physical devices. Is this procedure correct? Doing something similar will work for Zigbee radio/containers? Is there a “better” way to move the radios that won’t require me to rebuild my networks?
You have a number of steps to perform, each possible, and you want to do them in one fell swoop? What if one goes wrong?
Do your database conversion step first. Once that is out of the way, do the docker migration and hope the ZigBee devices come across, keeping in mind the docker device assignments for things like LAN, serial ports and USB Ports will need to match for a simple move without a lot of re-installation and reconfiguration
Take lots of snapshots/backups so you can roll back to a known scenario
I never moved docker containers from machine A to machine B. But the easiest thing to do is probably just to take hdd from macine A and plug it in machine B.
If that doesnt work copy entire docker dir where you store your containers and paste it to new hdd on machine B.
It’s docker
You copy files from A to b(rsync is good option for this)
After copy you just recreate docker and start container.
EDIT
Sorry, missed the DB changes
No. The database formats are not compatible and are in different locations.
Do your database conversion step first. Once you are confident they worked, tackle the rest. Don’t overcomplicate things by doing them all at once.
Do you have your zui store directory mapped outside the container?
I have moved my zwave-js instance around quite a bit. I just use the same docker compose file and copy the store directory (or use zui backup/restore). Adjust the controller mapping as needed. I always map to /dev/zwave so then the zwave-js config stays the same. May not change for you.
    devices:
      - '/dev/serial/by-id/usb-Zooz_800_Z-Wave_Stick_533D004242-if00:/dev/zwave'
Let me be a bit more specific. I typically do an NVM backup first and then restore to another controller and then use that in the new machine. I like to leave all the parts of the old setup in place just in case.
Oh, one more thing. That NVM backup and restore bit me not too long ago. I moved to a new machine, restored the store directory first and did the NVM restore after. The problem was the controller I was using was from a backup I had done many months before. So, it had the same Home ID as the “production” controller, but missing a bunch of devices I had included after that last backup. It apparently updated my data files back to how it was before I had a chance to do the NVM restore.
Tha is, if you use a different controller, do the NMV restore before restoring the zwave-js database files.
So you are using NVM backup/restore using two different machines and two different USB sticks? I’ve never done a backup/restore before, so I’m just inventing my own syntax below.
On MachineA with radio usbZwaveFoo create a backup named Feb14.bak:
NVMBackup(MachineA:usbZwaveFoo) —> Feb14.bak
Copy Feb14.bak to MachineB and restore that backup to radio usbZwaveBar:
NVMRestore(Feb14.bak, MachineB:usbZwaveBar)
Or are you doing a backup/restore and swapping the radio after the backup and before the restore?
Yes, If I remember correctly, I did the NVM backup and saved it to my laptop and likewise restored using the file on my laptop.
Where I got in trouble last time was that I restored the z-wave db files first and then plugged in an old z-wave stick (unknowingly, with my same home ID) and before I had time to restore the just-backed up NVM, it updated my DB files. Easy fix – just had to restore the DB files again.
Is it possible to backup/restore from A to B and move the radio from A to B?
bandit1
Does this make sense?
So I want to get HA running on a new host. In fact I have the host up and running. I have 2 USB sticks on the old host, one for Zwave and the other Zigbee. Both of those have WebApps that have backup/restore functions or manual methods. 'ESPHOME simply requires copying the devices folder
  1. NVM Backup old, backup USB stick(s) Dbs
  2. Move USB stick(s) from old box to new box
  3. NVM Restore, restore USB stick(s) Dbs
  4. Copy ESPHome folder from old to new
Finished?
