Moving max filter
I developed a filter sensor which creates a moving max sensor. You define a time window and within this time slot the maximum of the underlying sensor is taken. This is especially useful if you have a sensor with interrupted values, for example a sunlight sensor which is sometimes interrupted by shadows. With this moving max filter you get the envelope curve. One small disadvantage: if the values of the underlying sensor go down/decrease, the moving max filter will decrease with a delay of the time window.
original Sensor values:
resulting sensor (window size 10 minutes):
Sensor and Filter-Sensor together:
You got my interest with the comment on sunlight sensor and shadows.
My question is not directly related to your max filter (but may be). I have been attempting to automate cloud detection based on either UV, Solar Radiation, or LUX. I can easily tell if there are clouds based on a non-perfect bell curve shape. I don’t know how to proceed with automated detection.
You could check uv per lux (uv/lux). But I think your UV values are wrong. Normally you measure mW/m² and UVI=mW/m² divided by 25. 1 UVI = 25 mW/m²
Second, you could compare my moving max sensor with the lux sensor and if the difference was negative and becomes zero, then there was a cloud which is over now. So you know about clouds only when they are over.
I did not post the Canvas gauge that I have above those. The UV is reported in index. The Solar Radiation and LUX are the same sensor. UV is a separate sensor. The two different sensor measure slightly different wavelengths of light. These are direct imports from my weather station.
UV
Do you have the code to your max sensor handy or is it in HACS?
Hi martin 3000, sorry the link towards GITHUB is down. Can you check ?? Thx
Here goes the code. This is the original filter code from HA and 3 additional filters:
time moving max filter TimeMMFilter
time moving sum filter TimeMSFilter
You could also use this as a custom component. Therefore, you would need an __init__.py, services.yaml and manifest.json.
"""Allows the creation of a sensor that filters state property."""
from __future__ import annotations
from collections import Counter, deque
from copy import copy
from datetime import timedelta
from functools import partial
import logging
from numbers import Number
import statistics
import sys
import voluptuous as vol
from homeassistant.components.binary_sensor import DOMAIN as BINARY_SENSOR_DOMAIN
from homeassistant.components.input_number import DOMAIN as INPUT_NUMBER_DOMAIN
from homeassistant.components.recorder import history
from homeassistant.components.sensor import (
    DEVICE_CLASSES as SENSOR_DEVICE_CLASSES,
    DOMAIN as SENSOR_DOMAIN,
    PLATFORM_SCHEMA,
    SensorEntity,
from homeassistant.const import (
    ATTR_DEVICE_CLASS,
    ATTR_ENTITY_ID,
    ATTR_ICON,
    ATTR_UNIT_OF_MEASUREMENT,
    CONF_ENTITY_ID,
    CONF_NAME,
    STATE_UNAVAILABLE,
    STATE_UNKNOWN,
from homeassistant.core import callback
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.event import async_track_state_change_event
from homeassistant.helpers.reload import async_setup_reload_service
from homeassistant.util.decorator import Registry
import homeassistant.util.dt as dt_util
from . import DOMAIN, PLATFORMS
_LOGGER = logging.getLogger(__name__)
FILTER_NAME_RANGE = "range"
FILTER_NAME_LOWPASS = "lowpass"
FILTER_NAME_OUTLIER = "outlier"
FILTER_NAME_THROTTLE = "throttle"
FILTER_NAME_TIME_THROTTLE = "time_throttle"
FILTER_NAME_TIME_SMA = "time_simple_moving_average"
FILTER_NAME_TIME_MM = "time_moving_max"     # hüllkurve für sonneneinstrahlung
FILTER_NAME_TIME_MS = "time_moving_sum"     # kumuliert die erschütterungen der markise
FILTERS = Registry()
CONF_FILTERS = "filters"
CONF_FILTER_NAME = "filter"
CONF_FILTER_WINDOW_SIZE = "window_size"
CONF_FILTER_PRECISION = "precision"
CONF_FILTER_RADIUS = "radius"
CONF_FILTER_TIME_CONSTANT = "time_constant"
CONF_FILTER_LOWER_BOUND = "lower_bound"
CONF_FILTER_UPPER_BOUND = "upper_bound"
CONF_TIME_SMA_TYPE = "type"
TIME_SMA_LAST = "last"
WINDOW_SIZE_UNIT_NUMBER_EVENTS = 1
WINDOW_SIZE_UNIT_TIME = 2
DEFAULT_WINDOW_SIZE = 1
DEFAULT_PRECISION = 2
DEFAULT_FILTER_RADIUS = 2.0
DEFAULT_FILTER_TIME_CONSTANT = 10
NAME_TEMPLATE = "{} filter"
ICON = "mdi:chart-line-variant"
FILTER_SCHEMA = vol.Schema(
    {vol.Optional(CONF_FILTER_PRECISION, default=DEFAULT_PRECISION): vol.Coerce(int)}
FILTER_OUTLIER_SCHEMA = FILTER_SCHEMA.extend(
        vol.Required(CONF_FILTER_NAME): FILTER_NAME_OUTLIER,
        vol.Optional(CONF_FILTER_WINDOW_SIZE, default=DEFAULT_WINDOW_SIZE): vol.Coerce(
            int
        vol.Optional(CONF_FILTER_RADIUS, default=DEFAULT_FILTER_RADIUS): vol.Coerce(
            float
FILTER_LOWPASS_SCHEMA = FILTER_SCHEMA.extend(
        vol.Required(CONF_FILTER_NAME): FILTER_NAME_LOWPASS,
            int
        vol.Optional(
            CONF_FILTER_TIME_CONSTANT, default=DEFAULT_FILTER_TIME_CONSTANT
        ): vol.Coerce(int),
FILTER_RANGE_SCHEMA = FILTER_SCHEMA.extend(
        vol.Required(CONF_FILTER_NAME): FILTER_NAME_RANGE,
        vol.Optional(CONF_FILTER_LOWER_BOUND): vol.Coerce(float),
        vol.Optional(CONF_FILTER_UPPER_BOUND): vol.Coerce(float),
FILTER_TIME_SMA_SCHEMA = FILTER_SCHEMA.extend(
        vol.Required(CONF_FILTER_NAME): FILTER_NAME_TIME_SMA,
        vol.Optional(CONF_TIME_SMA_TYPE, default=TIME_SMA_LAST): vol.In(
            [TIME_SMA_LAST]
        vol.Required(CONF_FILTER_WINDOW_SIZE): vol.All(
            cv.time_period, cv.positive_timedelta
FILTER_TIME_MM_SCHEMA = FILTER_SCHEMA.extend(
        vol.Required(CONF_FILTER_NAME): FILTER_NAME_TIME_MM,
FILTER_TIME_MS_SCHEMA = FILTER_SCHEMA.extend(
        vol.Required(CONF_FILTER_NAME): FILTER_NAME_TIME_MS,
FILTER_THROTTLE_SCHEMA = FILTER_SCHEMA.extend(
        vol.Required(CONF_FILTER_NAME): FILTER_NAME_THROTTLE,
            int
FILTER_TIME_THROTTLE_SCHEMA = FILTER_SCHEMA.extend(
        vol.Required(CONF_FILTER_NAME): FILTER_NAME_TIME_THROTTLE,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
        vol.Required(CONF_ENTITY_ID): vol.Any(
            cv.entity_domain(SENSOR_DOMAIN),
            cv.entity_domain(BINARY_SENSOR_DOMAIN),
            cv.entity_domain(INPUT_NUMBER_DOMAIN),
        vol.Optional(CONF_NAME): cv.string,
        vol.Required(CONF_FILTERS): vol.All(
            cv.ensure_list,
                vol.Any(
                    FILTER_OUTLIER_SCHEMA,
                    FILTER_LOWPASS_SCHEMA,
                    FILTER_TIME_SMA_SCHEMA,
                    FILTER_TIME_MM_SCHEMA,
                    FILTER_TIME_MS_SCHEMA,
                    FILTER_THROTTLE_SCHEMA,
                    FILTER_TIME_THROTTLE_SCHEMA,
                    FILTER_RANGE_SCHEMA,
async def async_setup_platform(hass, config, async_add_entities, discovery_info=None):
    """Set up the template sensors."""
    await async_setup_reload_service(hass, DOMAIN, PLATFORMS)
    name = config.get(CONF_NAME)
    entity_id = config.get(CONF_ENTITY_ID)
    filters = [
        FILTERS[_filter.pop(CONF_FILTER_NAME)](entity=entity_id, **_filter)
        for _filter in config[CONF_FILTERS]
    async_add_entities([SensorFilter(name, entity_id, filters)])
class SensorFilter(SensorEntity):
    """Representation of a Filter Sensor."""
    def __init__(self, name, entity_id, filters):
        """Initialize the sensor."""
        self._name = name
        self._entity = entity_id
        self._unit_of_measurement = None
        self._state = None
        self._filters = filters
        self._icon = None
        self._device_class = None
    @callback
    def _update_filter_sensor_state_event(self, event):
        """Handle device state changes."""
        _LOGGER.debug("Update filter on event: %s", event)
        self._update_filter_sensor_state(event.data.get("new_state"))
    @callback
    def _update_filter_sensor_state(self, new_state, update_ha=True):
        """Process device state changes."""
        if new_state is None:
            _LOGGER.warning(
                "While updating filter %s, the new_state is None", self._name
            self._state = None
            self.async_write_ha_state()
            return
        if new_state.state in [STATE_UNKNOWN, STATE_UNAVAILABLE]:
            self._state = new_state.state
            return
        temp_state = new_state
        try:
            for filt in self._filters:
                filtered_state = filt.filter_state(copy(temp_state))
                _LOGGER.debug(
                    "%s(%s=%s) -> %s",
                    filt.name,
                    self._entity,
                    temp_state.state,
                    "skip" if filt.skip_processing else filtered_state.state,
                if filt.skip_processing:
                    return
                temp_state = filtered_state
        except ValueError:
            _LOGGER.error(
                "Could not convert state: %s (%s) to number",
                new_state.state,
                type(new_state.state),
            return
        self._state = temp_state.state
        if self._icon is None:
            self._icon = new_state.attributes.get(ATTR_ICON, ICON)
        if (
            self._device_class is None
            and new_state.attributes.get(ATTR_DEVICE_CLASS) in SENSOR_DEVICE_CLASSES
            self._device_class = new_state.attributes.get(ATTR_DEVICE_CLASS)
        if self._unit_of_measurement is None:
            self._unit_of_measurement = new_state.attributes.get(
        if update_ha:
    async def async_added_to_hass(self):
        """Register callbacks."""
        if "recorder" in self.hass.config.components:
            history_list = []
            largest_window_items = 0
            largest_window_time = timedelta(0)
            # Determine the largest window_size by type
                if (
                    filt.window_unit == WINDOW_SIZE_UNIT_NUMBER_EVENTS
                    and largest_window_items < filt.window_size
                    largest_window_items = filt.window_size
                elif (
                    filt.window_unit == WINDOW_SIZE_UNIT_TIME
                    and largest_window_time < filt.window_size
                    largest_window_time = filt.window_size
            # Retrieve the largest window_size of each type
            if largest_window_items > 0:
                filter_history = await self.hass.async_add_executor_job(
                    partial(
                        history.get_last_state_changes,
                        self.hass,
                        largest_window_items,
                        entity_id=self._entity,
                if self._entity in filter_history:
                    history_list.extend(filter_history[self._entity])
            if largest_window_time > timedelta(seconds=0):
                start = dt_util.utcnow() - largest_window_time
                    partial(
                        history.state_changes_during_period,
                        self.hass,
                        start,
                            state
                            for state in filter_history[self._entity]
                            if state not in history_list
            # Sort the window states
            history_list = sorted(history_list, key=lambda s: s.last_updated)
            _LOGGER.debug(
                "Loading from history: %s",
                [(s.state, s.last_updated) for s in history_list],
            # Replay history through the filter chain
            for state in history_list:
                if state.state not in [STATE_UNKNOWN, STATE_UNAVAILABLE, None]:
                    self._update_filter_sensor_state(state, False)
        self.async_on_remove(
            async_track_state_change_event(
                self.hass, [self._entity], self._update_filter_sensor_state_event
    @property
    def name(self):
        """Return the name of the sensor."""
        return self._name
    @property
    def state(self):
        """Return the state of the sensor."""
        return self._state
    @property
    def icon(self):
        """Return the icon to use in the frontend, if any."""
        return self._icon
    @property
    def unit_of_measurement(self):
        """Return the unit_of_measurement of the device."""
        return self._unit_of_measurement
    @property
    def should_poll(self):
        """No polling needed."""
        return False
    @property
    def extra_state_attributes(self):
        """Return the state attributes of the sensor."""
        return {ATTR_ENTITY_ID: self._entity}
    @property
    def device_class(self):
        """Return device class."""
        return self._device_class
class FilterState:
    """State abstraction for filter usage."""
    def __init__(self, state):
        """Initialize with HA State object."""
        self.timestamp = state.last_updated
        try:
            self.state = float(state.state)
        except ValueError:
            self.state = state.state
    def set_precision(self, precision):
        """Set precision of Number based states."""
        if isinstance(self.state, Number):
            value = round(float(self.state), precision)
            self.state = int(value) if precision == 0 else value
    def __str__(self):
        """Return state as the string representation of FilterState."""
        return str(self.state)
    def __repr__(self):
        """Return timestamp and state as the representation of FilterState."""
        return f"{self.timestamp} : {self.state}"
class Filter:
    """Filter skeleton."""
    def __init__(
        self,
        name,
        window_size: int = 1,
        precision: int | None = None,
        entity: str | None = None,
        """Initialize common attributes.
        :param window_size: size of the sliding window that holds previous values
        :param precision: round filtered value to precision value
        :param entity: used for debugging only
        if isinstance(window_size, int):
            self.states = deque(maxlen=window_size)
            self.window_unit = WINDOW_SIZE_UNIT_NUMBER_EVENTS
        else:
            self.states = deque(maxlen=0)
            self.window_unit = WINDOW_SIZE_UNIT_TIME
        self.precision = precision
        self._name = name
        self._skip_processing = False
        self._window_size = window_size
        self._store_raw = False
        self._only_numbers = True
    @property
    def window_size(self):
        """Return window size."""
        return self._window_size
    @property
    def name(self):
        """Return filter name."""
        return self._name
    @property
    def skip_processing(self):
        """Return whether the current filter_state should be skipped."""
        return self._skip_processing
    def _filter_state(self, new_state):
        """Implement filter."""
        raise NotImplementedError()
    def filter_state(self, new_state):
        """Implement a common interface for filters."""
        fstate = FilterState(new_state)
        if self._only_numbers and not isinstance(fstate.state, Number):
            raise ValueError(f"State <{fstate.state}> is not a Number")
        filtered = self._filter_state(fstate)
        filtered.set_precision(self.precision)
        if self._store_raw:
            self.states.append(copy(FilterState(new_state)))
        else:
            self.states.append(copy(filtered))
        new_state.state = filtered.state
        return new_state
@FILTERS.register(FILTER_NAME_RANGE)
class RangeFilter(Filter, SensorEntity):
    """Range filter.
    Determines if new state is in the range of upper_bound and lower_bound.
    If not inside, lower or upper bound is returned instead.
    def __init__(
        self,
        entity,
        precision: int | None = DEFAULT_PRECISION,
        lower_bound: float | None = None,
        upper_bound: float | None = None,
        """Initialize Filter.
        :param upper_bound: band upper bound
        :param lower_bound: band lower bound
        super().__init__(FILTER_NAME_RANGE, precision=precision, entity=entity)
        self._lower_bound = lower_bound
        self._upper_bound = upper_bound
        self._stats_internal = Counter()
        """Implement the range filter."""
        if self._upper_bound is not None and new_state.state > self._upper_bound:
            self._stats_internal["erasures_up"] += 1
            _LOGGER.debug(
                "Upper outlier nr. %s in %s: %s",
                self._stats_internal["erasures_up"],
                self._entity,
                new_state,
            new_state.state = self._upper_bound
        elif self._lower_bound is not None and new_state.state < self._lower_bound:
            self._stats_internal["erasures_low"] += 1
            _LOGGER.debug(
                "Lower outlier nr. %s in %s: %s",
                self._stats_internal["erasures_low"],
                self._entity,
                new_state,
            new_state.state = self._lower_bound
        return new_state
@FILTERS.register(FILTER_NAME_OUTLIER)
class OutlierFilter(Filter, SensorEntity):
    """BASIC outlier filter.
    Determines if new state is in a band around the median.
    def __init__(self, window_size, precision, entity, radius: float):
        :param radius: band radius
        super().__init__(FILTER_NAME_OUTLIER, window_size, precision, entity)
        self._radius = radius
        self._store_raw = True
        """Implement the outlier filter."""
        median = statistics.median([s.state for s in self.states]) if self.states else 0
        if (
            len(self.states) == self.states.maxlen
            and abs(new_state.state - median) > self._radius
            self._stats_internal["erasures"] += 1
            _LOGGER.debug(
                "Outlier nr. %s in %s: %s",
                self._stats_internal["erasures"],
                self._entity,
                new_state,
            new_state.state = median
        return new_state
@FILTERS.register(FILTER_NAME_LOWPASS)
class LowPassFilter(Filter, SensorEntity):
    """BASIC Low Pass Filter."""
    def __init__(self, window_size, precision, entity, time_constant: int):
        """Initialize Filter."""
        super().__init__(FILTER_NAME_LOWPASS, window_size, precision, entity)
        self._time_constant = time_constant
        """Implement the low pass filter."""
        if not self.states:
            return new_state
        new_weight = 1.0 / self._time_constant
        prev_weight = 1.0 - new_weight
        new_state.state = (
            prev_weight * self.states[-1].state + new_weight * new_state.state
        return new_state
@FILTERS.register(FILTER_NAME_TIME_SMA)
class TimeSMAFilter(Filter, SensorEntity):
    """Simple Moving Average (SMA) Filter.
    The window_size is determined by time, and SMA is time weighted.
    def __init__(
        self, window_size, precision, entity, type
    ):  # pylint: disable=redefined-builtin
        :param type: type of algorithm used to connect discrete values
        super().__init__(FILTER_NAME_TIME_SMA, window_size, precision, entity)
        self._time_window = window_size
        self.last_leak = None
        self.queue = deque()
    def _leak(self, left_boundary):
        """Remove timeouted elements."""
        while self.queue:
            if self.queue[0].timestamp + self._time_window <= left_boundary:
                self.last_leak = self.queue.popleft()
            else:
                return
        """Implement the Simple Moving Average filter."""
        self._leak(new_state.timestamp)
        self.queue.append(copy(new_state))
        moving_sum = 0
        start = new_state.timestamp - self._time_window
        prev_state = self.last_leak or self.queue[0]
        for state in self.queue:
            moving_sum += (state.timestamp - start).total_seconds() * prev_state.state
            start = state.timestamp
            prev_state = state
        new_state.state = moving_sum / self._time_window.total_seconds()
        return new_state
# jms: time moving max filter
@FILTERS.register(FILTER_NAME_TIME_MM)
class TimeMMFilter(Filter, SensorEntity):
    """ Moving Max (MM) Filter.
    The window_size is determined by time.
    def __init__(
        super().__init__(FILTER_NAME_TIME_MM, window_size, precision, entity)
        while self.queue:
            else:
                return
        """Implement the Moving Max filter."""
        maximum = sys.float_info.min
            maximum = max(maximum, prev_state.state)
            prev_state = state
        new_state.state = maximum
        return new_state
# jms: time moving sum filter
@FILTERS.register(FILTER_NAME_TIME_MS)
class TimeMSFilter(Filter, SensorEntity):
    """ Moving Sum (MS) Filter.
    def __init__(
        super().__init__(FILTER_NAME_TIME_MS, window_size, precision, entity)
        while self.queue:
            else:
                return
        """Implement the Moving Sum filter."""
        xsum = 0
            xsum = xsum + prev_state.state
            prev_state = state
        new_state.state = xsum
        return new_state
@FILTERS.register(FILTER_NAME_THROTTLE)
class ThrottleFilter(Filter, SensorEntity):
    """Throttle Filter.
    One sample per window.
    def __init__(self, window_size, precision, entity):
        super().__init__(FILTER_NAME_THROTTLE, window_size, precision, entity)
        self._only_numbers = False
        """Implement the throttle filter."""
        if not self.states or len(self.states) == self.states.maxlen:
            self.states.clear()
        else:
            self._skip_processing = True
        return new_state
@FILTERS.register(FILTER_NAME_TIME_THROTTLE)
class TimeThrottleFilter(Filter, SensorEntity):
    """Time Throttle Filter.
    One sample per time period.
        super().__init__(FILTER_NAME_TIME_THROTTLE, window_size, precision, entity)
        self._last_emitted_at = None
        """Implement the filter."""
        window_start = new_state.timestamp - self._time_window
        if not self._last_emitted_at or self._last_emitted_at <= window_start:
            self._last_emitted_at = new_state.timestamp
        else:
        return new_state
Hi Martin,this is perfectly what i need. But i am a newbe in Python… I know YAML and Automation now, and i managed to copy paste some PY scripts for automation. But how to implement this code (specially the section for time moving max “Moving Max (MM) Filter” into my HA ??
You have to copy it into a directory “custom_components/filter” (that you have to create maybe) inside home assistants config directory. The 4 files are here:
