Moving my ZHA network from one machine to another (same dongle)
How do I go about moving my ZHA network over to my new server (using the same dongle)? I’ve been enjoying starting fresh to clean out the cobwebs, but I don’t fancy pairing all my zigbee devices again.
Thank you!
I had to do this when I migrated from a Raspberry Pi 4 to a Dell micro PC. Once I had installed HA on the PC and restored a backup of HA I simply plugged in my dongle (Conbee 2) and it worked. I’m using ZHA too. Good luck.
Unfortunately, I’m not restoring a backup. I’m starting fresh - the only thing I’d like to move is the zigbee network. Is there any way to do that?
Any updates on this?
Try this guys video.
It’s for migrating to a new radio but it goes through the process of backing up zigbee network and I would assume the process to restore from backup is possible. The original posters probably were before the backup feature was there for just the zigbee network
Did you ever find a solution to this or did you just manually rebuild the network on your new instance? When I heard all about the ZHA/backup restore feature a few months ago, I assumed the entities etc were being backed up as well, but it appears to be specifically for changing Zigbee devices on the same instance.
