Moving Switchbot Tilt cover group simultaneously
I have a cover group, created using default helpers, consisting of three SwitchBot Blind Tilt devices (connected via Raspberry Pi 4b+ built-in Bluetooth).
The group used to move simultaneously, but after some Bluetooth issues with HAOS 10 were fixed, they now only move one at a time, resulting in it taking almost a minute to open and the “wow” factor really disappearing.
Is there something wrong with my configuration causing curtain actions to not run in parallel, or anything I can do to restore that functionality?
I am experiencing the same problem with the same setup (3 Switch Bot Blind Tilts in a group @ Raspi4) I just got them a few days ago and was a bit disappointed that they only move one at a time. At least good to hear that’s not the expected behavior.
Same problem here, and still not fixed. :frowning:
After I added a Bluetooth Proxy in my setup they move simultaneously. So this “fixed” it for me.
Hi Sysim, could you explain this in more detail? Thanks in advance!
I added a ESPHome Device in reach of the blinds and activated the Bluetooth Proxy Feature in the ESPHome device configuation via:
bluetooth_proxy:
  active: true
This made bluetooth much more responsive in general and the blind group workes as expected since then.
