Moving switches config from configuration.yaml to switches.yaml
I am trying to move switches config from main configuration.yaml to switches.yaml by following the docs but it’s not working. what am I doing wrong?
It’s not a switch platform it’s a light platform. It belongs under
light:
Not under:
switch:
Hi @Tismo
Could you provide the relevant bit of yaml from configuration.yaml - the include bit. Also, please provide the yaml from your switches.yaml file.
In both cases, please copy the text to your reply and format the code properly - using three back ticks on each side of the code.
That was it. Thank you @tom_l
