This has been a project I have been attempting for a couple days now. I have an automation that successfully uses calendar.get_events. However, to clean things up and make it more versatile in the future, I would like to template the get_events call along with checking a string against the list of events. Ideally I would like to pass in a calendar, as the entity_id, along with a string, and have it return true or false.
I have added the automation that currently works.
- platform: time
at: "06:45:00"
condition: []
- service: calendar.get_events
duration:
hours: 24
minutes: 0
seconds: 0
response_variable: cal_events
entity_id:
- calendar.bartley_events
- if:
- condition: or
conditions:
- condition: template
value_template: |-
{%- set fms = namespace(event=false) %}
{%- for key, value in cal_events.items() %}
{%- for event in value.events if 'No School' in event.summary %}
{%- set fms.event = true %}
{%- endfor %}
{%- endfor %}
{{ fms.event }}
- condition: time
weekday:
- sat
- sun
then:
- delay:
hours: 1
minutes: 15
seconds: 0
milliseconds: 0
- service: script.heater_on_sequence
data: {}
else:
data: {}
I think you’re talking about something like:
alias: Calendar Content Check
sequence:
start_date_time: "{{ now() }}"
duration:
hours: "{{ hours }}"
minutes: 0
seconds: 0
entity_id: "{{ calendars }}"
- variables:
c: |
{%- for event in value.events if search_term in event[calendar_element] %}
{%- endfor %}
{%- endfor %}
{{ {"match": fms.event} }}
- stop: Respond with content match
mode: parallel
fields:
calendars:
selector:
entity:
multiple: true
filter:
- domain: calendar
required: true
search_term:
selector:
text: null
default: No School
required: true
calendar_element:
selector:
select:
options:
- summary
- description
- location
required: true
hours:
selector:
number:
min: 1
max: 168
default: 24
required: true
You would then call that as a service:
alias: zTest calendar content
sequence:
- service: script.calendar_content_check
search_term: No School
hours: 24
calendars:
- calendar.bartly_events
calendar_element: summary
response_variable: "results"
- if:
- or:
value_template: "{{ results.match }}"
- condition: time
weekday:
- sat
- sun
then:
- delay:
hours: 1
minutes: 15
seconds: 0
milliseconds: 0
data: {}
else:
data: {}
mode: single
Though such an extended delay is not advised.
The purpose of the delay in this specific case is because the wife and kids sleep in on none school days. The heater is out in the barn, and is only used for the duration while they are doing chores. Most days they will turn if off when complete. If they don’t, I have a step to turn it off after they should be done with chores.
I have have other automations I want to trigger at different times depending upon what is on the calendar, hence figuring out this script.
If there are better ways of having the trigger fire off at different times it I’m always willing to learn.
I’ve been trying to figure out how to do this kind of thing for months. I’d love to see this filtering capability built into the HA calendar integration as a core service. I slightly modified this to return all filtered matches as a list of date objects. I’m using this to determine my first meeting of the day, and enable/disable some automations depending on if I’m out of office or not.
alias: Search calendar
sequence:
duration:
hours: "{{ days*24 }}"
minutes: 0
seconds: 0
- variables:
c: |
{%- set fms = namespace(events=[]) %}
{%- for event in value.events if search_term in event["summary"] %}
{%- set fms.events = fms.events + [event] %}
{%- endfor %}
{%- endfor %}
{{ {"match": fms.events} }}
mode: parallel
fields:
calendars:
selector:
entity:
multiple: true
filter:
- domain: calendar
required: true
days:
selector:
number:
min: 1
max: 365
default: 1
required: true
search_term:
selector:
text: null
default: Busy
required: true
icon: mdi:calendar
