Moving to Has.io - how do I move zwave cfg
I’m finally getting around to using Hass.io instead of my trusty AIO install.
I’d like to keep all of the customized names for my zwave devices. Customizations that I did via the OpenZwave Control Panel.
What do I need to do to keep these customized names? Do I just copy my zwcfg_XXXXX.xml file? Where-to?
copy everything in your HA folder can copy it to the config folder in hass.io
The easiest way I found was to install the samba add-on and just drag and drop into the config share.
Thanks. I also had to remove the config_path key from my zwave configuration. But it looks like everything is working…
