Hello!
After the update to 2022.4, my MPD player fails to receive a service call.
I trigger it via:
service: media_player.play_media
media_content_id: door.mp3
media_content_type: music
entity_id: media_player.mpd
Here’s the error:
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 193, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1634, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1671, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 282, in service_handler
await script_entity.async_turn_on(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 386, in async_turn_on
await coro
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 412, in _async_run
return await self.script.async_run(script_vars, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1275, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 359, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 379, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 582, in _async_call_service_step
await service_task
task.result()
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 677, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 955, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 714, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/mpd/media_player.py", line 479, in async_play_media
media_id = async_process_play_media_url(self.hass, media_id)
File "/usr/src/homeassistant/homeassistant/components/media_player/browse_media.py", line 40, in async_process_play_media_url
raise ValueError("URL is relative, but does not start with a /")
ValueError: URL is relative, but does not start with a /
The underlying media_player is the MPD add-on, when I click the play button over its GUI, the sound is being played with no problem.
This issue did not occur with 2022.3.
