i started with a fresh install of HA 2021-3-4 in my back up HA on raspberry pi 3b (latest available version as of today), added following lines to the configuration.yaml
media_player:
- platform: mpd
host: 192.168.2.32
i see the entity media_player.mpd but it shows unavailable. it seems to work fine on my primary HA on raspberry pi 3b running core-2021.1.5. I cant really remember if there are any additional steps required.
Use case is to play tts through local audio jack with speakers connected
no error related to this in the logs. only error i am seeing is
Logger: homeassistant
Source: config_entries.py:568
First occurred: 1:43:40 AM (1 occurrences)
Last logged: 1:43:40 AM
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 561, in async_create_flow
integration.get_platform("config_flow")
File "/usr/src/homeassistant/homeassistant/loader.py", line 499, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 504, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 973, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'homeassistant.components.vlc_telnet.config_flow'
File "/usr/src/homeassistant/homeassistant/components/hassio/discovery.py", line 89, in async_process_new
await self.hass.config_entries.flow.async_init(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 122, in async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 568, in async_create_flow
raise data_entry_flow.UnknownHandler
homeassistant.data_entry_flow.UnknownHandler
@nickrout- yes that is correct. since i couldn’t get the MPD to work in this latest HA version, i was trying to see if i can use VLC addon- the problem with that is the vlc_telnet integration requires mentioning password but the VLC add on that was added in the latest release of HA does not have place to assign a password
but really i am just trying to get the MPD platform to work (works fine on another PI which is running HA core-2021.1.5 version)
on the same PI running Hassio- i think the problem is i dont have the mopidy addon installed and I am not able to install it for some reason with the latest version of HA- i have used this repository in the past but its not loading in the current version of HA
this is the error message i get
21-03-18 05:16:43 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/bestlibre/hassio-addons/tree/master/mopidy repository
21-03-18 05:16:43 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/bestlibre/hassio-addons/tree/master/mopidy repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/bestlibre/hassio-addons/tree/master/mopidy /data/addons/git/5708a1bf
stderr: 'Cloning into '/data/addons/git/5708a1bf'...
fatal: repository 'https://github.com/bestlibre/hassio-addons/tree/master/mopidy/' not found
21-03-18 05:16:43 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / 5708a1bf
21-03-18 05:16:43 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/bestlibre/hassio-addons/tree/master/mopidy
