Hi All,
I’ve been trying for days now to get an MPU6050 setup and working but keep getting a “[E][component:092]: Component was marked as failed.” error followed by a “communication with MPU6050 failed!” error. And of course, no values are reported. Havent had much luck finding resources with possible resolutions. Logs posted below. From what I can tell i2C bus is working, and finds the device address without issue. I have tried 3 x MPU6050 with 2 x other nodemcus. Also swapped out jumper wires a couple of times. No change.
Setup is using a Nodemcu 8266 and connected as follows:
3V3 -> VCC
GND -> GND
D2 -> SDA
D3 -> SCL
Log output containing error:
[23:07:29][C][api:022]: Setting up Home Assistant API server...
[23:07:29][C][mpu6050:024]: Setting up MPU6050...
[23:07:29][VV][i2c:056]: Beginning Transmission to 0x68:
[23:07:29][VV][i2c:093]: Writing 0b01110101 (0x75)
[23:07:29][VV][i2c:061]: Transmission ended. Status code: 0x00
[23:07:29][VV][i2c:083]: Requesting 1 bytes from 0x68:
[23:07:29][VV][i2c:113]: Received 0b00001110 (0x0E)
[23:07:29][E][component:092]: Component was marked as failed.**
[23:07:29][VV][scheduler:057]: set_interval(name='update', interval=200, offset=3)
[23:07:29][I][app:059]: setup() finished successfully!
[23:07:29][I][app:105]: ESPHome version 1.17.0-dev compiled on Jan 13 2021, 23:05:50
[23:07:29][C][wifi:443]: WiFi:
[23:07:29][C][wifi:303]: SSID:
[23:07:29][C][wifi:304]: IP Address:
[23:07:29][C][wifi:306]: BSSID:
[23:07:29][C][wifi:307]: Hostname: 'test_nodes'
[23:07:29][C][wifi:311]: Signal strength: -21 dB ▂▄▆█
[23:07:29][C][wifi:315]: Channel: 6
[23:07:29][C][wifi:316]: Subnet:
[23:07:29][C][wifi:317]: Gateway:
[23:07:29][C][wifi:318]: DNS1: (IP unset)
[23:07:29][C][wifi:319]: DNS2: (IP unset)
[23:07:29][C][i2c:028]: I2C Bus:
[23:07:29][C][i2c:029]: SDA Pin: GPIO4
[23:07:29][C][i2c:030]: SCL Pin: GPIO0
[23:07:29][C][i2c:031]: Frequency: 50000 Hz
[23:07:29][I][i2c:033]: Scanning i2c bus for active devices...
[23:07:29][I][i2c:040]: Found i2c device at address 0x68
[23:07:29][C][logger:185]: Logger:
[23:07:29][C][logger:186]: Level: VERY_VERBOSE
[23:07:29][C][logger:187]: Log Baud Rate: 115200
[23:07:29][C][logger:188]: Hardware UART: UART0
[23:07:29][C][captive_portal:169]: Captive Portal:
[23:07:29][C][ota:029]: Over-The-Air Updates:
[23:07:29][C][ota:030]: Address:
[23:07:29][C][api:095]: API Server:
[23:07:29][C][api:096]: Address:
[23:07:29][C][mpu6050:085]: MPU6050:
[23:07:29][C][mpu6050:086]: Address: 0x68
[23:07:29][E][mpu6050:088]: Communication with MPU6050 failed!
[23:07:29][C][mpu6050:090]: Update Interval: 0.2s
[23:07:29][C][mpu6050:091]: Acceleration X 'Washer Accel X'
[23:07:29][C][mpu6050:091]: Unit of Measurement: 'm/s²'
[23:07:29][C][mpu6050:091]: Accuracy Decimals: 2
[23:07:29][C][mpu6050:091]: Icon: 'mdi:briefcase-download'
[23:07:29][C][mpu6050:092]: Acceleration Y 'Washer Accel Y'
[23:07:29][C][mpu6050:092]: Unit of Measurement: 'm/s²'
[23:07:29][C][mpu6050:092]: Accuracy Decimals: 2
[23:07:29][C][mpu6050:092]: Icon: 'mdi:briefcase-download'
[23:07:29][C][mpu6050:093]: Acceleration Z 'Washer Accel Z'
[23:07:29][C][mpu6050:093]: Unit of Measurement: 'm/s²'
[23:07:29][C][mpu6050:093]: Accuracy Decimals: 2
[23:07:29][C][mpu6050:093]: Icon: 'mdi:briefcase-download'
Am I missing something obvious here with my setup? Appreciate any assistance/guidance.
