I’ve been using a private addon for the last year and decided to publish it today. It’s been working great for what I need, but having refactored the code for deployment according the the Home Assistant docs, I’m not certain that my docker images work on all of the platforms. I did bake my build commands into the Makefile if anyone wants to peep it and see if my cross platform builds look sensical. I was also confused by some of the architecture types, for instance is armhf and armv7 the same thing? I run my Home Assistant on an Ubuntu VM on my FreeNAS server and don’t have a test bed for these other platforms, but I did my best in publishing the images.
The addon repo I made is at GitHub - lovesway/hassio-addons: Home Assistant addon repository for apps developed at Love's Way.
The Makefile with my docker build syntax is at hassio-addons/Makefile at master · lovesway/hassio-addons · GitHub
Any help/tips are appreciated. Even a confirmation that anyone can install a particular arch type would be great. Once I work the build out, I’ll make a how to video and complete the docs. It does work well and to my knowledge there isn’t any other app that will let you make light shows in this way; it may have benefit to others. Also feel free to point me to any other forums or categories, I couldn’t find a spot that seemed dedicated to addon development.
Thanks!
