MQTT 502 Bad Gateway error
Sorry if this has been reposted, my MQTT add-on stopped working all of a sudden after i tried adding a Sonoff presence sensor and it now shows a 502 Bad Gateway error. Tried stopping and restarting the add-on but still the same. Have also tried replugging the dongle.
Dongle - smlight slzb-06p7
HA Core - 2024.11.3
MQTT - 1.40.1-1
Mosquitto - 6.4.1
Here’s the log for MQTT add-on
[21:25:54] INFO: Preparing to start...
[21:25:55] INFO: Socat not enabled
[21:25:59] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
/app/node_modules/js-yaml/lib/loader.js:183
  return new YAMLException(message, mark);
YAMLException: unknown tag !<!include_dir_merge_named> (18:42)
 15 |  ... authorized: true
 16 |  ... 4
 17 |  ...
 18 |  ... include_dir_merge_named themes
 19 |  ... 9
 20 |  ...  options are optional
    at generateError (/app/node_modules/js-yaml/lib/loader.js:183:10)
    at throwError (/app/node_modules/js-yaml/lib/loader.js:187:9)
    at composeNode (/app/node_modules/js-yaml/lib/loader.js:1521:7)
    at readBlockMapping (/app/node_modules/js-yaml/lib/loader.js:1164:11)
    at composeNode (/app/node_modules/js-yaml/lib/loader.js:1441:12)
    at readDocument (/app/node_modules/js-yaml/lib/loader.js:1625:3)
    at loadDocuments (/app/node_modules/js-yaml/lib/loader.js:1688:5)
    at Object.load (/app/node_modules/js-yaml/lib/loader.js:1714:19)
Here’s the log from mosquitto
[20:45:17] INFO: Successfully send discovery information to Home Assistant.
[20:45:19] INFO: Successfully send service information to the Supervisor.
2024-12-03 20:45:24: New connection from 172.30.32.1:18539 on port 1883.
2024-12-03 20:45:24: New client connected from 172.30.32.1:18539 as 6LWTBYytctPKaxnXY3OwQE (p2, c1, k60, u'homeassistant').
2024-12-03 20:46:16: New connection from 172.30.32.2:58392 on port 1883.
2024-12-03 20:46:16: Client <unknown> closed its connection.
2024-12-03 20:48:16: New connection from 172.30.32.2:37716 on port 1883.
2024-12-03 20:48:16: Client <unknown> closed its connection.
2024-12-03 20:50:16: New connection from 172.30.32.2:39384 on port 1883.
2024-12-03 20:50:16: Client <unknown> closed its connection.
2024-12-03 20:52:16: New connection from 172.30.32.2:53330 on port 1883.
2024-12-03 20:52:16: Client <unknown> closed its connection.
2024-12-03 20:54:16: New connection from 172.30.32.2:33440 on port 1883.
2024-12-03 20:54:16: Client <unknown> closed its connection.
2024-12-03 20:56:16: New connection from 172.30.32.2:48304 on port 1883.
2024-12-03 20:56:16: Client <unknown> closed its connection.
2024-12-03 20:58:16: New connection from 172.30.32.2:33830 on port 1883.
2024-12-03 20:58:16: Client <unknown> closed its connection.
2024-12-03 21:00:17: New connection from 172.30.32.2:48356 on port 1883.
2024-12-03 21:00:17: Client <unknown> closed its connection.
2024-12-03 21:02:17: New connection from 172.30.32.2:34366 on port 1883.
2024-12-03 21:02:17: Client <unknown> closed its connection.
2024-12-03 21:04:17: New connection from 172.30.32.2:39600 on port 1883.
2024-12-03 21:04:17: Client <unknown> closed its connection.
2024-12-03 21:06:17: New connection from 172.30.32.2:44392 on port 1883.
2024-12-03 21:06:17: Client <unknown> closed its connection.
2024-12-03 21:08:17: New connection from 172.30.32.2:33384 on port 1883.
2024-12-03 21:08:17: Client <unknown> closed its connection.
2024-12-03 21:10:17: New connection from 172.30.32.2:48342 on port 1883.
2024-12-03 21:10:17: Client <unknown> closed its connection.
2024-12-03 21:12:17: New connection from 172.30.32.2:52044 on port 1883.
2024-12-03 21:12:17: Client <unknown> closed its connection.
2024-12-03 21:14:17: New connection from 172.30.32.2:34290 on port 1883.
2024-12-03 21:14:17: Client <unknown> closed its connection.
2024-12-03 21:15:15: Saving in-memory database to /data//mosquitto.db.
2024-12-03 21:16:17: New connection from 172.30.32.2:36062 on port 1883.
2024-12-03 21:16:17: Client <unknown> closed its connection.
2024-12-03 21:18:17: New connection from 172.30.32.2:33982 on port 1883.
2024-12-03 21:18:17: Client <unknown> closed its connection.
2024-12-03 21:20:17: New connection from 172.30.32.2:34260 on port 1883.
2024-12-03 21:20:17: Client <unknown> closed its connection.
2024-12-03 21:22:17: New connection from 172.30.32.2:38722 on port 1883.
2024-12-03 21:22:17: Client <unknown> closed its connection.
2024-12-03 21:24:17: New connection from 172.30.32.2:43102 on port 1883.
2024-12-03 21:24:17: Client <unknown> closed its connection.
2024-12-03 21:26:17: New connection from 172.30.32.2:37312 on port 1883.
2024-12-03 21:26:17: Client <unknown> closed its connection.
2024-12-03 21:28:17: New connection from 172.30.32.2:51136 on port 1883.
2024-12-03 21:28:17: Client <unknown> closed its connection.
2024-12-03 21:30:17: New connection from 172.30.32.2:55466 on port 1883.
2024-12-03 21:30:17: Client <unknown> closed its connection.
2024-12-03 21:32:17: New connection from 172.30.32.2:57160 on port 1883.
2024-12-03 21:32:17: Client <unknown> closed its connection.
2024-12-03 21:34:17: New connection from 172.30.32.2:55780 on port 1883.
2024-12-03 21:34:17: Client <unknown> closed its connection.
2024-12-03 21:36:17: New connection from 172.30.32.2:39670 on port 1883.
2024-12-03 21:36:17: Client <unknown> closed its connection.
2024-12-03 21:38:17: New connection from 172.30.32.2:58434 on port 1883.
2024-12-03 21:38:17: Client <unknown> closed its connection.
2024-12-03 21:40:17: New connection from 172.30.32.2:46316 on port 1883.
2024-12-03 21:40:17: Client <unknown> closed its connection.
2024-12-03 21:42:17: New connection from 172.30.32.2:54502 on port 1883.
2024-12-03 21:42:17: Client <unknown> closed its connection.
2024-12-03 21:44:17: New connection from 172.30.32.2:39928 on port 1883.
2024-12-03 21:44:17: Client <unknown> closed its connection.
2024-12-03 21:45:16: Saving in-memory database to /data//mosquitto.db.
2024-12-03 21:46:17: New connection from 172.30.32.2:51106 on port 1883.
2024-12-03 21:46:17: Client <unknown> closed its connection.
2024-12-03 21:48:17: New connection from 172.30.32.2:47452 on port 1883.
2024-12-03 21:48:17: Client <unknown> closed its connection.
2024-12-03 21:50:17: New connection from 172.30.32.2:34716 on port 1883.
2024-12-03 21:50:17: Client <unknown> closed its connection.
This is the log of Zigbee2MQTT…
…and that is not correct for the Z2M configuration
Thank you so much, that solved the issue
