Mqtt add-on Stop working
hey,
Suddenly my Mqtt add-on stopped working.
when i click start it does not do anything.,
also, from the add-on LOG i have this error: Error grabbing logs: EOF
what should i need to do?
I have tried to uninstall and reinstall it again , same problem.
[homeassistant.components.mqtt] Failed to connect due to exception: [Errno -3] Try again
[homeassistant.setup] Setup failed for mqtt: Component failed to initialize.
i run this command sudo /etc/init.d/mosquitto status
here is the output:
https://hastebin.com/orezaqufes.sql
So, I do not know what happened with this Add-on,but I deleted it from my Hassio.
I installed Mosquitto in the old way from the Terminal.
now My Mqtt broker back to work.
