I’m trying to get MQTT auto discovery working. As far as I can see, HA is not listening on the “homeassistant/#” topic.
I have the MQTT Mosquitto integration installed. MQTT integration has “Enable newly added entities.” switch turned on.
MQTT broker has the default configuration and it is working except for discovery.
I have some MQTT lights configured manually in “light.yaml” like:
- platform: mqtt
schema: json
state_topic: "mydomain/light/Livingroom/state"
command_topic: "mydomain/light/Livingroom/set"
brightness: true
brightness_scale: 100
optimistic: false
qos: 0
These lights work fine and I can control them with something like:
mosquitto_pub -h 127.0.0.1 -p 1883 -t "mydomain/light/Lavanderia/set" -m '{"state":"ON","brightness":50,"indicator":"ON"}' -u USER -P PASS
The log shows:
2020-11-02 23:50:41 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2020-11-02 23:50:41 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds
2020-11-02 23:50:43 INFO (Thread-5) [homeassistant.components.mqtt] Connected to MQTT server core-mosquitto:1883 (0)
2020-11-02 23:50:43 INFO (MainThread) [homeassistant.components.light] Setting up light.mqtt
2020-11-02 23:50:47 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to mydomain/light/Livingroom/state, mid: 21
I am testing MQTT discovery with the example in the documentation (MQTT - Home Assistant) using mosquitto:
mosquitto_pub -h 127.0.0.1 -p 1883 -t "homeassistant/binary_sensor/garden/config" -m '{"name": "garden", "device_class": "motion", "state_topic": "homeassistant/binary_sensor/garden/state"}' -u USER -P PASS
And also with
Developer tools > MQTT > Publish a packet
topic: "homeassistant/binary_sensor/garden/config"
payload: '{"name": "garden", "device_class": "motion", "state_topic": "homeassistant/binary_sensor/garden/state"}'
The log only shows the transmission, but is not receiving:
2020-11-03 00:51:21 DEBUG (MainThread) [homeassistant.components.mqtt] Transmitting message on homeassistant/binary_sensor/garden/config: '{"name": "garden", "device_class": "motion", "state_topic": "homeassistant/binary_sensor/garden/state"}', mid: 43
I am running:
- HassOS 4.15
- Home Assistant 0.117.2
- Mosquitto broker 5.1
With debug enabled in the logger (configuration.yaml):
logger:
default: info
logs:
homeassistant.components.mqtt: debug
custom_components.my_integration: debug
It was also not working before my last update.
I have tried changing the “Enable newly added entities.” switch on and off and configuring discovery manually:
mqtt:
discovery: true
discovery_prefix: homeassistant
I have tried the examples in MQTT auto discovery isn't working, but messages are visible with no success.
Anybody got any idea what I am missing?
Regards,
JA
