I am trying to control my external alarm system (an old Texecom (non-Elite) alarm system) through Home Assistant.
I am using the MQTT Alarm Panel integration, since this allows external code validation and using Node-Red I can transform messages from my alarm system (UDP messages) to MQTT messages that make sense to HA.
My alarm panel is set up like this:
alarm_control_panel:
- name: "Texecom Alarm Panel"
unique_id: "Texecom_Premier88_AlarmPanel"
state_topic: "texecom2mqtt/panel"
value_template: "{{ value_json.alarm_state }}"
command_topic: "texecom2mqtt/panel/set"
code: REMOTE_CODE
command_template: >
{ "action": "{{ action }}", "code": "{{ code }}" }
Via MQTT Explorer, I can see that the status is send correctly to the right topic:
However, the status of my alarm panel remains “Unknown”.
The opposite direction, arming the alarm seems to work fine.
I’m seeing the output as expected in MQTT explorer:
So what am I overlooking so that the alarm_state is not picked up by my alarm panel?
