I am new to Home Assistant and am trying to integrate sensors run on a Raspberry Pi with a HA system based on another RPi using MQTT.
According to MQTT Sensor - Home Assistant, there has been a recent change in configuration.yaml to the format:
Example configuration.yaml entry
mqtt:
- state_topic: “home/bedroom/temperature”
However nearly all examples on the web use the earlier ‘platform mqtt’ method.
I have separated out the sensor to sensor.yaml in the form
mqtt:
- name: rpi4 cpu load
state_topic: "masoko/rpi4/cpuload"
unit_of_measurement: "%"
- name: rpi4 cpu temp
state_topic: "masoko/rpi4/cputemp"
unit_of_measurement: "°C"
- ... etc
but Studio Code Server says 'Missing property “Platform” ’ against the mqtt: line.
I am assuming that I am using mismatched Home Assistant ( Home Assistant 2022.8.6 Supervisor 2022.08.3 Operating System 8.5 Frontend 20220802.0 - latest ) and Studio Code Server.
What should I do?
