Hello there
first of all, dear community, thanks for that great tool! I’ve installed it on my Hyper-V cluster and it worked out of the box. I’m saying that, because it makes two things clear: yes I like Hyper-V and yes I’m a 100% Geek and techie So I’ve started to have HA in virtualenv with Ubuntu (I love [!] Linux as well) I ordered some esp8266 (esp01) and started to automate. So far I run out of IP addresses in /24 but that’s a different story.
Now to my issue: One of them should actually set up my lighting in the living room. That works out quite well with a H801 (also ESP8266) dimmer and MQTT broker. But the espEasy + PCA9685 config won’t work.
The problem is, that I’m messing up subscriptions and push templates in MQTT and/or espEasy.
espEasy says:
- Subscribe Template: “/%sysname%/#”
- Publish Template: “/%sysname%/%tskname%/%valname%”
So I have in the configuration to dimm the channel 0
- platform: mqtt
state_topic: "/IoT02/PCAPWM/0"
command_topic: "/IoT02/PCAPWM/0"
brightness_state_topic: "/IoT02/PCAPWM/0"
brightness_command_topic: "/IoT02/PCAPWM/0"
state_value_template: "{{ value_json.state }}"
brightness_value_template: "{{ value_json.brightness }}"
qos: 0
payload_on: "4096"
payload_off: "0"
optimistic: false
I assume the problem is in the topics, but I have no idea how to differ between "state" and "set" as I also don't know how to differ between Subscribe and Publish template in espEasy. I am so into that topic, that I don't see the problem. I know that it is not correct to have state and set in the same message cue, but I simply don't know how.
I have additional questions like:
Why does my chromecast audio (in a different LAN that is routed transparent) not show up?
How can I setup a trigger that is fired when I switch the input of my ONKYO receiver?
But I will ask them in a different Topic.
Regards, Lukas
