MQTT and zigbee2mqtt no device discovery in HA
Hello to all, I’m trying to setup zigbee2mqtt and it is not working properly, yet.
In the log of zigbee2mqtt I can see that its connected to mosquitto and that there are two devices connected through zigbee, but there aren’t discovered in Home Assistant.
I’ve tried everything for the past two days I red on forum’s and I haven’t make any progress…
configuration.yaml:
mqtt:
  broker: 192.169.1.2
  port: 1883
  discovery: true
  # discovery_prefix: homeassistant
  birth_message:
    topic: 'hass/status'
    payload: 'online'
  will_message:
    payload: 'offline'
zigbee2mqtt config in the add-on:
  "data_path": "/share/zigbee2mqtt",
  "devices": "devices.yaml",
  "groups": "groups.yaml",
  "homeassistant": true,
  "permit_join": false,
  "mqtt": {
    "base_topic": "zigbee2mqtt",
    "server": "mqtt://homeassistant",
    "user": "mqttuser",
    "password": "XXXX"
  "serial": {
    "port": "/dev/ttyACM0"
  "advanced": {
    "pan_id": 6754,
    "channel": 11,
    "network_key": [
      106,
      106,
      146,
      141,
      112,
      110,
      0,
      148,
      137,
      11,
      79,
      59,
      127,
      179,
      57,
      65
    "availability_blacklist": []
  "ban": [],
  "whitelist": [],
  "queue": {}
mosquitto config in the add-on:
  "logins": [
      "username": "mqttuser",
      "password": "XXXX"
  "anonymous": false,
  "customize": {
    "active": true,
    "folder": "mosquitto"
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem"
accesscontrollist:
user mqttuser
topic readwrite #
Logging in zigbee2mqtt:
  zigbee2mqtt:info 8/1/2019, 7:22:42 PM Logging to directory: '/share/zigbee2mqtt/log/2019-08-01.19-22-41'
  zigbee2mqtt:info 8/1/2019, 7:22:42 PM Starting zigbee2mqtt version 1.5.1 (commit #unknown)
  zigbee2mqtt:info 8/1/2019, 7:22:42 PM Starting zigbee-shepherd
  zigbee2mqtt:info 8/1/2019, 7:22:44 PM zigbee-shepherd started
  zigbee2mqtt:info 8/1/2019, 7:22:44 PM Coordinator firmware version: '20190608'
  zigbee2mqtt:info 8/1/2019, 7:22:44 PM Currently 2 devices are joined:
  zigbee2mqtt:info 8/1/2019, 7:22:44 PM sensor_bureau (0x00158d0002d77a9f): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
  zigbee2mqtt:info 8/1/2019, 7:22:44 PM ledstrip_keuken (0x00124b001d3aaed9): GL-C-006/GL-C-009 - Gledopto Zigbee LED controller WW/CW Dimmer (Router)
  zigbee2mqtt:info 8/1/2019, 7:22:44 PM Zigbee: disabling joining new devices.
  zigbee2mqtt:info 8/1/2019, 7:22:44 PM Connecting to MQTT server at mqtt://homeassistant
  zigbee2mqtt:info 8/1/2019, 7:22:44 PM zigbee-shepherd ready
  zigbee2mqtt:info 8/1/2019, 7:22:45 PM Connected to MQTT server
  zigbee2mqtt:info 8/1/2019, 7:22:45 PM MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
  zigbee2mqtt:info 8/1/2019, 7:22:45 PM MQTT publish: topic 'zigbee2mqtt/sensor_bureau', payload '{"temperature":24.51,"linkquality":23,"humidity":56.19,"pressure":1012.8,"battery":86,"voltage":2975}'
  zigbee2mqtt:info 8/1/2019, 7:22:45 PM MQTT publish: topic 'homeassistant/sensor/0x00158d0002d77a9f/temperature/config', payload '{"unit_of_measurement":"°C","device_class":"temperature","value_template":"{{ value_json.temperature }}","state_topic":"zigbee2mqtt/sensor_bureau","json_attributes_topic":"zigbee2mqtt/sensor_bureau","name":"sensor_bureau_temperature","unique_id":"0x00158d0002d77a9f_temperature_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0002d77a9f"],"name":"sensor_bureau","sw_version":"Zigbee2mqtt 1.5.1","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
Nothing to see in the discovery:
mqtt_nodiscovery
I hope I have added sufficient resources and that I missed something in the configuration for you to help me out… don’t hesitate to ask for more.
Did you forget to tick the Discovery box when setting up the integration of MQTT?
Capture
Thanks Akriss, this was the solution:
because HA automatic added the integration it didn’t work.
I had to remove the integration and re-ad it with the settings you show, and tick the discovery box.
